Error message.
- Newcastle Flyer
Re: Error message.
I've noticed when you use the Youtube tag, that the posts don't show the Youtube videos. If it's your post, you have to press edit, and copy the Youtube URL in between the Youtube tags.
White lives matter too.
Australia Day 26th Jan, the most important day in Australia as is 19 April, Cook's discovery of eastern Australia
- Newcastle Flyer
Re: Error message.
^^ Fleet Lists, and I hope Boxythingy doesn't mind, but I wanted to find the youtube tags in a post that wasn't mine.
See: https://busaustralia.com/forum/viewtopi ... 0#p1064070
That big space is meant to be a Youtube video using the Youtube video tags.
It's the same in several browser brands.
- ScaniaGrenda
Re: Error message.
TESTING:
https://youtu.be/JYbiP_DOGJQ
Google Chrome: No go, as Newcastle Flyer states there is just a big blank space where the embedded video should be with the start of the Youtube tag missing but the videos address and closing youtube tag are still visible.
Re: Error message.
And the one initially reported also contained faulty tags which I hope have now been fixed
- Newcastle Flyer
Re: Error message.
Here is an example of the Youtube tags still not working from one of my posts:
No error whatsoever in the address from my thread here: https://busaustralia.com/forum/viewtopi ... 65#p973765
Re: Error message.
Because you are also using wrong tags - I am not planning to fix everyones tags - that is up to individual editors.
There should in fact be no tags and just the Youtube URL as shown in ScaniaGrenda's post above.
Re: Error message.
I tested it myself (without posting). Blank still. However, still have Flashcontrol installed on the computer I am writing this from, which shows the video in the test post as a Flash object.
Same video, coded in the post dialog same way:
Some years ago, I believe YouTube warned users that embed function was deprecated. Cannot recall any specifics, so it isn't likely a useful thing to include here.
Now, I cannot recall the exact specifics of Adobe Flash finally being a thing of the past, but I do believe it was designed to cease working from the End-Of-Life date. That seemed like a possible explanation for why the videos are not showing here until I tried on another board that uses phpBB - and found the video worked fine. Same video, coded in the post dialog same way:
Code: Select all
[youtube]XMCBwQGjl-4[/youtube]
Re: Error message.
I am no expert in this area but I believe you could well be right. In the latest one pointed at by Newcastle Flyer, I found it dates back to 2016 so I suspect it would have worked back then. I have now changed it to the latest what I know where only the URL is displayed and then you click on that to display it. It could be that this started recently when we went to the latest version of pppBB while the other board referred to has not yet updated to the latest version.
Re: Error message.
It looks like the Youtube tag was just added as a custom BB code setting. That still embeds the Youtube video using Flash, which is dead. It's probably better to remove this setting and install the MediaEmbed plugin - https://www.phpbb.com/customise/db/exte ... ediaembed/
Re: Error message.
This is now well beyond me so I have referred it to higher authorities.
- Bus Suggestions
Re: Error message.
I'm getting new error messages now, hasn't happened before. On the top of the index page, I'm receiving this:
When entering the topic pages (i.e. Pictures/Discussion), the message doubles up (i.e. line 257, 319, then 257, 319).
As I am posting this, the posting page error has expanded to:
When clearing cookies, I recieve:
I can't even add attachments, as it returns:
Code: Select all
[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 257: mysqli_fetch_assoc(): Couldn't fetch mysqli_result
[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 319: mysqli_free_result(): Couldn't fetch mysqli_result
Code: Select all
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4127: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3006)
Code: Select all
AJAX ERROR
Something went wrong with the request and the server returned an invalid reply.
Code: Select all
ERROR
Could not upload attachment to ./files/21240_0d3d67c84c99e4ba1ce39dac5e524cad.
Re: Error message.
It appears that we ran over some of our memory limits but hopefully that has now been resolved.
- Bus Suggestions
Re: Error message.
It has indeed been resolved.
Re: Error message.
Lately i have been getting a lot of
Sorry but you cannot use search at this time. The server has high load. Please try again later.
messages when I log on or move from one topic to another.
Re: Error message.
I thought I had replied to this earlier.
This seems to have started yesterday morning.
I had been about to post a message whether whether were also having this problem.
I have since escalated the problem
Re: Error message.
Was getting the message again for last couple of hours.
Re: Error message.
The following is appearing on the page header when I loaded the board on my phone's browser just now:
Code: Select all
phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 264: mysqli_fetch_assoc(): Couldn't fetch mysqli_result
[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 326: mysqli_free_result(): Couldn't fetch mysqli_result
[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 264: mysqli_fetch_assoc(): Couldn't fetch mysqli_result
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4149: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3027)
- Off The Rails
Re: Error message.
Also happens on Chrome. Same text as Merc1107's.
Cheers!
Cheers!
- Bus Suggestions
Re: Error message.
I’ve also been getting that message, as well as the following when I try to get to a topic from my unread notifications:
Code: Select all
Fatal: Not able to open ./cache/production/data_global.php
Re: Error message.
I'm getting the message on Firefox and Safari, but the board is still loading OK
Re: Error message.
Seems there hasn't been any new posts since 2.44 pm Sunday?
Re: Error message.
It's been basically impossible to log in for most of the last couple of days. Managed it now but it feels like a fluke.boronia wrote:Seems there hasn't been any new posts since 2.44 pm Sunday?
Catch a Traklink bus and you're on the train.
Re: Error message.
Not to mention I can only see the last page of this thread while logged out or in a different browser
