Transtopic wrote: ↑Wed Mar 01, 2023 10:19 pm
Minns didn't say that the rapid bus network would replace the metro lines, but promised to implement it in time for the airport's opening in 2026, which had been the LNP government's commitment, but they've been tardy in implementing it. The only metro line that will be completed in time for the airport's opening will be the WSA metro from St Marys. The rest are still a long way off. Your comments about Labor's past policies are completely irrelevant.
When Labor talks buses, it's to replace trains or trams. That's been a consistent outcome with them for generations. It's like the kiss of death. They will promise the higher capacity mode at the outset, then keep deferring it until finally arguing that it isn't necessary after all, all the while the potential patronage that can't fit on board bleeds off into their private cars. It's happened for too long to think otherwise. If some future Labor government breaks the spell, well and good, but I'll believe it when I see it. This is why I hark back to the 1950s as an example, when new railway lines were promised to replace the trams and then they prematurely got rid of the trams anyway and brought in the buses before those railways were built. It was the Coalition that finally started the ESR, only to have it cut short by the following Labor government. Carr did the same and it will likely happen again if Minns wins. They're already talking up a crabwalk out of it.
Fairfield Mayor Frank Carbone's criticism of Labor's policy is just grandstanding in a political ploy to run in the election for the seat of Cabramatta as an Independent. He would be well aware that Parramatta, Fairfield, Cabramatta and Liverpool already have a direct rail connection with Leppington on the SWRL and a potential extension to the Aerotropolis via the Cumberland Line. There is potential for this link to be further upgraded with higher frequencies and reduced journey times. He has no ideas what he's talking about.
Even the briefest glimpse at a map reveals that there is a huge mass of urban area in W/SW Sydney that is away from a railway - which only skirts its eastern edge, thus requiring feeder buses. This mass will gradually spread westwards into the Kemps Creek area and, of course, across to the Western Sydney Metro corridor. There is no PT of any significance servicing that mass apart from, yes, another T Way which is good up to the point of its fairly low capacity ceiling (like the NW T Way), but way way short of being a railway.
Those two metro corridors from Westmead and Bankstown will go through the heart of this huge area and need to be included in the coordinated business case because it's all an integrated, planned network, part of a citywide plan, not a bunch of separated, piecemeal rail lines. This is the difference between the sort of planning vision and perspective you get from a Coalition government, compared to what you get from a Labor government. That's another thing that Labor needs to learn to do properly.
Carbone's right on the ball and Liverpool and Campbelltown share his concerns too. That's a huge chunk of LGAs lined up against Labor.
