PTA / Transperth & Private Observations - 2022
Re: PTA / Transperth & Private Observations - 2022
Set 127 recently transferred to Nowergup RCD
car numbers are as follows CEA-CEC-CED-CEE-CEF-CEB.
CEA-CEC-CED-CEE-CEF-CEB.TP1462 wrote:Set 127 recently transferred to Nowergup RCD
1127. 2127-3127-4127-5217 6127
- Bus-1809
2297 now at Karrinyup too. Sighted earlier on a 400 or whatever it is now.
By my calculations, this means that Transdev no longer have any Voith B7 Optimus units, thank God!
- Off The Rails
2156 would like to say hi
1354 on 207.
2750 is one of paths Xmas buses. Seen it at high Wycombe stn
- Woolies_truck
- Favourite Vehicle: MAN NG313F
TP1724 seen operating a 950F this evening.
3315 on 206.
3320 and 3321 sighted at Trucks Centre WA Kewdale.
Spotted 3323 newbie for swan while doing my 280 running around Hartman Park. Looks like test drive before been delivered
I work out of Mundaring depot, occasionally will work out of both ellenbrook and midvale depotsEnviro 500 wrote: ↑Wed Nov 30, 2022 12:15 amAre you a Midvale or Beckenham driver? I believe 280 is controlled from both depots.
Does MDG have its own permanent fleet?the c man wrote: ↑Wed Nov 30, 2022 8:27 amI work out of Mundaring depot, occasionally will work out of both ellenbrook and midvale depotsEnviro 500 wrote: ↑Wed Nov 30, 2022 12:15 am Are you a Midvale or Beckenham driver? I believe 280 is controlled from both depots.
Mundaring swaps around with midvale.
Ellenbrook has its own fleet from 1477-1479, 2446-2448, 2486-2490, 2512-2530, 2557, 2813-2815
Midvale/Mundaring fleet. 1466, 1472-1476, 1662, 2455, 2483-2485, 2491-2494, 2531-2536, 2550-2556, 2564-2574, 2812, 2816, 3020-3022, 3026, 3085, 3087
Apologies if this has already been mentioned but I saw 2799 on a 910 earlier this arvo on Canning highway westbound
Southern River-based 3137 is the first Transperth artic to feature the new front seat setup that is similar to the OC500LE/CR228L units.
2791 was moved to Beckenham just before the Airport Line opened, while 2792-9 wound up at Palmyra. Path Transit only has 2753-6, 2773-8 and 2783-90 left. However, they seem to have been given 3311.
Thanks it can be quite confusing to keep up with transfersEnviro 500 wrote:2791 was moved to Beckenham just before the Airport Line opened, while 2792-9 wound up at Palmyra. Path Transit only has 2753-6, 2773-8 and 2783-90 left. However, they seem to have been given 3311.
Sent from my iPad using Tapatalk
2751 now resides at Redcliffe; sighted entering Redcliffe Station yesterday night on a 935F.
- Bus-1809
1566 is also in service at Bayswater along with 1724. There may be a 3rd one going back into service, but can't be confirmed at this stage.
3315-3319 all at Beckenham I believe.
I believe Karrinyup's last Gas Bus has been transferred to TDWA, with 2038 moving south to Palmyra. 2607 has gone back North so is now at Swan. I'd assume that by now, the gas plant would have been turned off for the final time?
Enviro500, are you 100% sure that 2013-2037 are staying at Gosnells?
1567 and 1568 are in service at Bayswater.
2013-37 are still active in Thornlie region. Doubt they're leaving anytime soon.Bus-1809 wrote: ↑Wed Dec 07, 2022 6:56 pm 1566 is also in service at Bayswater along with 1724. There may be a 3rd one going back into service, but can't be confirmed at this stage.
- Bus Suggestions
3115 seems to be at Karrinyup.
3138 for Swan Transit, sighted at Trucks Centre Kewdale.
Word on the street is that...
1724 on Midland/Airport Line replacement!
