PTA / Transperth & Private Observations - 2021
Re: PTA / Transperth & Private Observations - 2021
1473 back in midvale today following refurb.
2996 in service at Fremantle
also it look like 2607 actually permanent transfer to claisbrook (probably replaced 1199/188) because i saw a lot doing yellow cat and also i not seen it around freo area. before i thought maybe just freo bus cover claisbrook shift for meal break but if that happen the bus should be rotate not same bus
saw 3246 on truck centre however when i look at it the sticker it say it operated by transdev not swan.not sure is it just temporary sticker or is it now transdev number will be same with swan because i thought transdev maybe get 33xx
Confirm 3245 and onwards are destined for Transdev.
Last edited by Zidanehartono on Tue Oct 26, 2021 5:29 pm, edited 2 times in total.
Hmm, interesting.Zidanehartono wrote: ↑Mon Oct 25, 2021 5:50 pmLooks like 3245 and onwards are destined for Transdev, sighted the aforementioned unit a few days ago but I couldn't see the operators sticker as there were other buses parked there too.
Any news of when 2791 will be allocated?
2264 sighted on a 403T to Perth Busport earlier this evening.
Apparently 2998 and 2999 are ready for revenue service but 2997 is still missing.
Either of them might still be at Trucks Centre Kewdale as per my sightings from yesterday.Enviro 500 wrote: ↑Fri Oct 29, 2021 2:14 am Apparently 2998 and 2999 are ready for revenue service but 2997 is still missing.
What do you mean?Enviro 500 wrote: ↑Fri Oct 29, 2021 2:14 am Apparently 2998 and 2999 are ready for revenue service but 2997 is still missing.
Perthbus.info lists 2998 and 2999 as active but doesn't mention 2997.Squiddy wrote: ↑Fri Oct 29, 2021 9:37 amWhat do you mean?Enviro 500 wrote: ↑Fri Oct 29, 2021 2:14 am Apparently 2998 and 2999 are ready for revenue service but 2997 is still missing.
Not sure why it doesnt appear on the list but 2997 has a listing you can access by clicking the arrows on 96/98Enviro 500 wrote: ↑Fri Oct 29, 2021 2:36 pmPerthbus.info lists 2998 and 2999 as active but doesn't mention 2997.
https://perthbus.info/report.php?vid=TP2997
2997 is confirmed as registered
Horizons West 1HID851 (ex-1754) sighted wearing the operator's corporate livery.
2997 is in service at Freo. Spotted in Wellington St, CBD.
2244 was spotted all the way out on Bennett Springs Drive in Bennett Springs for Driver Training.
with 1262-1265 withdrawn and 2262-2265 move to karrinyup from freo and 2078-2081 move from karrinyup to rockingham would that mean 1959-1962 move from rockingham to freo or would they just made the new 299x as replacement for the OC withdrawn (because before when all 226x move to freo i thought maybe to make straight swap for next batch and made 2081 below transfer to fremantle not rockingham and rockingham kept 19xx)
In a bit of a roundabout way the 299s should always be replacing the withdrawn 1200s. Though with it happening alongside Rockingham contract swapping a bunch of Volvos with Swan, I'd wager a bunch of B8s went to Rocky to avoid having too few Volvos there. Just a guess.pasha241 wrote: ↑Sun Oct 31, 2021 12:28 pm with 1262-1265 withdrawn and 2262-2265 move to karrinyup from freo and 2078-2081 move from karrinyup to rockingham would that mean 1959-1962 move from rockingham to freo or would they just made the new 299x as replacement for the OC withdrawn (because before when all 226x move to freo i thought maybe to make straight swap for next batch and made 2081 below transfer to fremantle not rockingham and rockingham kept 19xx)
Enviro 500 wrote: ↑Sat Oct 30, 2021 9:29 pmIs it now based at Midvale?
Not in midvale could be in ellenbrook, I'll check tomorrow
- Bus-1809
Not entirely... Operators are no longer being allocated individual blocks of fleet numbers... They will now share the same blocks as is done with the articsZidanehartono wrote: Confirm 3245 and onwards are destined for Transdev.
Meaning some of them could end up with Path? What about 2791-99?
Presumably Path will get those then once its filled up, they will get from the new general pool.Enviro 500 wrote: ↑Mon Nov 01, 2021 12:14 amMeaning some of them could end up with Path? What about 2791-99?
What about them? Obviously they're going to skip the last few 2700s and go straight to 3200s.Enviro 500 wrote: ↑Mon Nov 01, 2021 12:14 amMeaning some of them could end up with Path? What about 2791-99?
Obvious sarcasm is hopefully obvious, Swan went to 3200s after 2899, Transdev's going to 3200s after 2999, why would Path be any different?
1657 and 2310 back from refurb
