Transperth Bus Fleet by Depot / Region
Re: Transperth Bus Fleet by Depot / Region
1278, 1604, 1861-3 have all been laid up.
2227 and 2192 appear to be at Fremantle and Southern River respectively after being seen on 915 and 930.
Yeah definitely southern river for 2192Enviro 500 wrote:1278, 1604, 1861-3 have all been laid up.
Moved to Canning Vale along with 2190 and 91. 2227 more likely a change off.
Saw 2227 in Palmyra yard when I was there on Saturday I’ll be working from there and Rockingham soon
Which is a Canning Vale bus. The 517 is run by Canning Vale Beckenham and Southern River depots.Enviro 500 wrote: ↑Fri Mar 18, 2022 2:08 pm 2193 is also in the same region now. Just saw it on 517.
TP1462 reckons 2193 sister 2192 may be at SR. Not to mention Canning and SR packages often do cross regional deployment.PTObserver wrote: ↑Sat Mar 19, 2022 12:50 pmWhich is a Canning Vale bus. The 517 is run by Canning Vale Beckenham and Southern River depots.Enviro 500 wrote: ↑Fri Mar 18, 2022 2:08 pm 2193 is also in the same region now. Just saw it on 517.
- Bus Suggestions
Yet again, what's there to not understand? komen_413 has said it, Off The Rails over in observations has said twice now, 2190-2199 are all based in CV. Either way, they're all based around Canning or SR, why is it an argument?
Quite disappointing how a lack of common sense is used on your behalf, it's been stated numerous of times that 2190-93 have recently moved to CV what part of that don't you understand?!!Enviro 500 wrote: ↑Sat Mar 19, 2022 1:53 pmTP1462 reckons 2193 sister 2192 may be at SR. Not to mention Canning and SR packages often do cross regional deployment.PTObserver wrote: ↑Sat Mar 19, 2022 12:50 pm
It's a pity that numerous of members refrain from posting on this board as an amount of your posts clutter up the board by these useless arguments and speculations that lead to nowhere.
Evening all, it's been a while since the fleet listing has been updated so i've done my best to piece everything together. As always please sound off below if any amendments are required. cheers
===Path Transit===
Malaga:
104-108, 110, 111, 1399-1429, 1462, 1865-1879, 2004-2012, 2185-2186, 2310-2324, 2389-2390, 2729-2736, 2759-2776, 2783-2787, 2790-2791, 2794-2795, 3001, 3002, 3035, 3038, 3041, 3044, 3047, 3050, 3053, 3056, 3077, 3080, 3106, 3108, 3110
Bayswater:
1880-1899, 2000-2003, 2391-2399, 2737-2746, 2748-2749, 2751, 3059, 3062, 3065, 3068, 3071, 3083, 3086, 3088, 3096, 3097, 3098, 3112
Redcliffe:
2362-2388, 2707, 2713, 2716-2726, 2747, 2750, 2752-2758, 3016, 3017, 3027, 3028.
Kalamunda:
2325-2361, 2788-2789, 3005, 3010, 3011, 3029, 3030, 3031, 3032
Welshpool:
101-103, 1363-1371, 1373-1387, 1389-1398, 1430-1434, 1591, 1592, 1910-1917, 1919, 2175-2184, 2700-2706, 2708-2712, 2714-2715, 2727-2728, 2792-2793
===Swan Transit===
Canning Vale:
1656–1661, 1663-1665, 2190-2199, 2422–2426, 2463–2484, 2495–2511, 2575-2579, 2817–2825, 3034, 3052, 3055, 3058, 3061, 3064
Beckenham:
1666-1699, 2400-2418, 2449-2454, 2456-2462
Southern River:
1435-1439, 1605-1609, 1611-1625, 1627-1655, 2013-2031, 2427-2431
Karrinyup:
2032-2064, 2244, 2246-2277, 2419-2421, 2432-2445, 2539-2545, 2583-2589, 3003, 3004, 3007, 3009, 3013, 3014, 3019, 3023
Beenyup:
2546-2549, 2557-2563, 2889-2900, 3200-3226
Shenton Park:
2580-2582, 2590-2598, 2800-2811, 2826-2853, 2887-2888
Mount Claremont:
2854-2878, 3037, 3040, 3043, 3046, 3049, 3067, 3070, 3076, 3079, 3099-3102, 3105, 3107, 3109, 3111
Midvale/Ellenbrook:
1466, 1472-1479, 1662, 2446-2448, 2455, 2485-2494, 2512-2538, 2550-2556, 2564-2574, 2812-2816, 3020, 3021, 3022, 3026, 3085, 3087
Joondalup/Nowergup:
2152-2155, 2157-2160, 2165-2174, 2187-2189, 2599-2606, 2613, 2677, 2678, 2682, 2683, 2686-2698, 2879-2886, 2923-2927, 2933, 2939-2958, 2965, 2967-2968, 3033, 3039, 3042, 3057, 3078, 3227-3244, 3249-3251, 3256-3259, 4000-4001
Wangara:
2124-2134, 2136, 2138, 2146-2151, 2161-2164, 2642-2644, 2660, 2679, 2680, 2684, 2685, 2699, 2901-2905, 2909, 2910, 2917-2922, 3082, 3113-3118
===Transdev===
Rockingham:
RCCTS1-RCCTS4, 118-122, 1918, 2065-2097, 2280-2281, 2293-2296, 2607-2608, 2645-2646, 2928-2932, 2969, 2973-2977, 2983-2993, 3089-3093, 3245, 3248, 3252, 3253, 3255
Mandurah/Pinjarra:
2135, 2137, 2156, 2216-2243, 2609, 2611-2612, 2614-2616, 2636-2641, 2651, 2654-2659, 2661-2664, 2681, 2906-2908, 2911-2913, 2916, 2934-2938, 2959, 3006, 3008, 3012, 3015, 3018, 3024-3025
Fremantle:
112–117, 1279-1288, 1290-1297, 1299, 1900–1909, 1920-1999, 2200, 2278-2279, 2282-2292, 2297-2299, 2647-2650, 2652-2653, 2914–2915, 2960-2964, 2966, 2970-2972, 2978-2982, 2994-2999, 3036, 3045, 3048, 3051, 3054, 3060, 3063, 3066, 3069, 3072-3075, 3081, 3084, 3094, 3095, 3103-3104, 3119-3125, 3246-3247, 3254,
Claisebrook:
2139-2145, 2610, 2617-2635, 2665-2676, 2777-2782
===Path Transit===
Malaga:
Bayswater:
Redcliffe:
Kalamunda:
Welshpool:
===Swan Transit===
Canning Vale:
Beckenham:
Southern River:
Karrinyup:
Beenyup:
Shenton Park:
Mount Claremont:
Midvale/Ellenbrook:
Joondalup/Nowergup:
Wangara:
===Transdev===
Rockingham:
Mandurah/Pinjarra:
Fremantle:
Claisebrook:
Also we can't forget the Regionals
===Regionals===
Albany
1164, 1207, 1209, 1232, 1233, 1356, 1357, 1442-1450, 1771
Bridgetown
1204, 1231
Broome
2123, 2201-2203
Bunbury
1441, 1463, 1464, 1480-1499, 1572-1585
Busselton
1155-1157, 1174, 1220, 1500-1501, 1586-1590, 2109, 2112, 800, 801, 809-814, 816, 819-822, 828-833
Carnarvon
1205, 1206, 1208
Collie
1459, 1460
Esperance
1440, 1452-1457, 2107
Geraldton
1461, 1465, 2098, 2099, 2100-2105, 2110-2111, 2113-2118, 2209
Kalgoorlie
1467-1471, 2300-2308
Karratha
1458, 2108, 2204, 2210-2215
Kununurra
2309
Manjimup
1451
Narrogin
2106
Port Hedland
2119-2122, 2205-2208
===Regionals===
Albany
Bridgetown
1204, 1231
Broome
2123, 2201-2203
Bunbury
Busselton
Carnarvon
1205, 1206, 1208
Collie
1459, 1460
Esperance
Geraldton
Kalgoorlie
Karratha
Kununurra
2309
Manjimup
1451
Narrogin
2106
Port Hedland
And finally, the regos for 1234-1278 have all been cancelled.. they have either been disposed or are awaiting disposal, therefore I am only counting the registered vehicles in storage
Registered OC500LE CNG's in storage: 1604, 1855-1863
Registered Scania L94UA in storage: 3000 (last obserations in the forum noted this vehicle is awaiting parts)
Registered O405NH's either back in service for Transperth or returned to storage: 1160-1163, 1188, 1190, 1197, 1199, 1200, 1203, 1212-1219, 1221-1222, 1224-1230, 1301, 1332, 1342-1349, 1354-1355, 1359-1362, 1502, 1504, 1566-1571, 1724, 1827, 1840, 1843-1850
I would have serious reservations against believing such an observation (i.e. waiting on parts); poor 3000 is prone to much rumour and speculation.
3000 is an orphan in the Perth fleet, and like the orphans of bus fleets everywhere, it is predisposed to lengthy periods of time off the road. Compare that to other parts of Australia where large L94 fleets (diesel or gas) did or do run day in, day out, without question. I've heard such remarks as "X brand of bus doesn't work in Australia because it's too hot here", because their subfleet of X brand were beset with overheating issues from new. Meanwhile other cites in a similar climate run the same buses without fault, or worked around the issue.
As a fan of anything with the Griffin symbol that rolls, I feel bad for 3000 at times. In my home country we also had a sole L94 (Volgren CR221 body like the Dyson's ones in VIC) which was our first low-entry bus. As you can see from my profile, the vehicle I respect the most is the N113CRB (of which we had 200 back home) and I also have a soft spot for the €5 KUBs, which are still going strong.
Anyway, I'm pretty sure 1289 is long gone as it was apparently involved in a serious accident last year.
Is 2796 in service yet? Someone claims to have seen it in the Volvo yard at Welshpool recently.
B8s up to 2799 registered for Path Transit and allocated to their respective depots. So are those up to 3274 for Swan Transit and Transdev.
BZLs 4002 and 4003 look ready to enter service.
B7s 2600-2605 look like they're now based at CV, while 1656-1659 have gone to Albany.
OCs 1442-1445 are now in Port Hedland.
2032-7 most likely are now SR buses.
Update pre Airport Line Openign (CMIWW)
===Path Transit===
Malaga:
104-108, 110, 111, 1398-1429, 1462, 1865-1881, 2004-2012, 2185-2186, 2310-2324, 2389-2391, 2729-2736, 2759-2776, 2783-2787, 2790, 3001, 3002, 3035, 3038, 3041, 3044, 3047, 3050, 3053, 3056, 3077, 3080, 3106, 3108, 3110, 3130, 3132
Bayswater:
1881-1899, 2000-2003, 2392-2399, 2737-2746, 2748-2749, 2751, 3059, 3062, 3065, 3068, 3071, 3083, 3086, 3088, 3096, 3097, 3098, 3112
Redcliffe:
Kalamunda:
Welshpool:
101-103, 1363-1371, 1373-1387, 1389-1397, 1430-1434, 1591, 1592, 1910-1917, 1919, 2175-2184, 2700-2706, 2708-2712, 2714-2715, 2727-2728, 3131
===Swan Transit===
Canning Vale:
1665, 2124-2127, 2187-2199, 2422–2426, 2464–2482, 2495–2511, 2575-2579, 2599-2606, 2817–2825, 3034, 3052, 3055, 3058, 3061, 3064, 3126-3127
Beckenham:
1666-1699, 2400-2418, 2443-2445, 2449-2454, 2456-2463, 2590-2593
Southern River:
1435-1439, 1605-1609, 1611-1617, 1619-1625, 1627-1632, 1634-1655, 2013-2037, 2167-2174, 2427-2431, 3133-3136
Karrinyup:
2038-2055, 2244, 2246-2287, 2419-2423, 2432-2445, 2539-2547, 2580-2589, 2677-2680, 3003, 3004, 3007, 3009, 3013, 3014, 3019, 3023
Beenyup:
2548-2549, 2558-2563, 2889-2900, 3200-3226
Shenton Park:
2594-2598, 2800-2811, 2826-2854, 2887-2888
Mount Claremont:
2854-2878, 3037, 3040, 3043, 3046, 3049, 3067, 3070, 3076, 3079, 3099-3102, 3105, 3107, 3109, 3111, 3128-3129
Midvale/Ellenbrook:
1466, 1472-1479, 1662, 2379-2380, 2446-2448, 2455, 2483-2494, 2512-2538, 2550-2557, 2564-2574, 2812-2816, 3020, 3021, 3022, 3026, 3085, 3087
Joondalup/Nowergup:
2152-2166, 2682, 2683, 2686-2698, 2879-2886, 2923-2927, 2933, 2939-2958, 2965, 2967-2968, 3033, 3039, 3042, 3057, 3078, 3227-3244, 3249-3251, 3256-3281, 4000-4001
Wangara:
2128-2134, 2136, 2138, 2146-2152, 2161-2164, 2613, 2642-2644, 2660, 2684, 2685, 2699, 2901-2905, 2909, 2910, 2917-2922, 3082, 3113-3118
===Transdev===
Rockingham:
RCCTS1-RCCTS4, 118-122, 1918, 2065-2097, 2280-2281, 2293-2296, 2607-2608, 2645-2646, 2928-2932, 2969, 2973-2977, 2983-2993, 3089-3093, 3245, 3248, 3252-3255
Mandurah/Pinjarra:
Fremantle:
112–117, 1290-1292, 1295-1297, 1299, 1900–1908, 1920, 1925-1999, 2056-2057, 2200, 2288-2299, 2607-2608, 2647-2650, 2652-2653, 2792-2799, 2914–2915, 2960-2964, 2966, 2970-2972, 2978-2982, 2994-2999, 3036, 3045, 3048, 3051, 3054, 3060, 3063, 3066, 3069, 3072-3075, 3081, 3084, 3094, 3095, 3103-3104, 3119-3125, 3246-3247, 3282-3292
Claisebrook:
===Path Transit===
Malaga:
Bayswater:
Redcliffe:
Kalamunda:
Welshpool:
===Swan Transit===
Canning Vale:
Beckenham:
Southern River:
Karrinyup:
Beenyup:
Shenton Park:
Mount Claremont:
Midvale/Ellenbrook:
Joondalup/Nowergup:
Wangara:
===Transdev===
Rockingham:
Mandurah/Pinjarra:
Fremantle:
Claisebrook:
1212 and 1504 are at Freo currently. Last I saw, 1504 still has the Trans Esperance sticker on the engine cover.
1211 is down at Sunbury bus depot VictoriaEnviro 500 wrote: ↑Sun Aug 14, 2022 5:22 pm 1211 and 1504 are at Freo currently. Last I saw, 1504 still has the Trans Esperance sticker on the engine cover.
Sorry, I meant 1212. Spotted this on 111 the same day 1504 was seen on 910.the c man wrote: ↑Sun Aug 14, 2022 7:38 pm1211 is down at Sunbury bus depot VictoriaEnviro 500 wrote: ↑Sun Aug 14, 2022 5:22 pm 1211 and 1504 are at Freo currently. Last I saw, 1504 still has the Trans Esperance sticker on the engine cover.
Midis on a 111Enviro 500 wrote: ↑Sun Aug 14, 2022 9:13 pm Sorry, I meant 1212. Spotted this on 111 the same day 1504 was seen on 910.
Nothing exactly new. I have spotted 113 on a 111 before. Freo's CAT-spec OCs rarely come into the CBD nowadays, unlike those from Welshpool and Malaga.Merc1107 wrote: ↑Fri Aug 26, 2022 8:55 pmMidis on a 111Enviro 500 wrote: ↑Sun Aug 14, 2022 9:13 pm Sorry, I meant 1212. Spotted this on 111 the same day 1504 was seen on 910.
Few minor amendments and also recent transfers for PATH
1398, 1880 and 2391 are Malaga buses now.
3130 is at Malaga
3131 is at Welshpool
3130 is at Malaga
===Path Transit===
Malaga:
104-108, 110, 111, 1398-1429, 1462, 1865-1881, 2003-2012, 2185-2186, 2310-2324, 2389-2391, 2729-2736, 2759-2776, 2783-2787, 2790, 3001, 3002, 3035, 3038, 3041, 3044, 3047, 3050, 3053, 3056, 3077, 3080, 3106, 3108, 3110, 3130, 3132
Bayswater:
1881-1899, 2000-2002, 2392-2399, 2737-2746, 2748-2749, 2751, 3059, 3062, 3065, 3068, 3071, 3083, 3086, 3088, 3096, 3097, 3098, 3112
Redcliffe:
2362-2378, 2381-2388, 2707, 2713, 2716-2726, 2747, 2750, 2752-2758, 3016, 3017, 3027, 3028.
Kalamunda:
Welshpool:
===Swan Transit===
Canning Vale:
Beckenham:
Southern River:
Karrinyup:
Beenyup:
Shenton Park:
Mount Claremont:
Midvale/Ellenbrook:
Joondalup/Nowergup:
Wangara:
===Transdev===
Rockingham:
Mandurah/Pinjarra:
Fremantle:
Claisebrook:
===Path Transit===
Malaga:
Bayswater:
Redcliffe:
Kalamunda:
Welshpool:
===Swan Transit===
Canning Vale:
Beckenham:
Southern River:
Karrinyup:
Beenyup:
Shenton Park:
Mount Claremont:
Midvale/Ellenbrook:
Joondalup/Nowergup:
Wangara:
===Transdev===
Rockingham:
Mandurah/Pinjarra:
Fremantle:
Claisebrook:
2379-80 are no longer at RCDEP.
Also, what happened to 1633?
