Denning Landseer - Only Starts from Sub starter
New Users (or anyone else) is/are welcome to ask questions in here to which the answers might be obvious to most but you simply don't know yourself or are unsure where to find the answer. You can also ask questions about the working of the forum or anything else you may think of.
TroyP-4216
Favourite Vehicle: Denning Landseer
Post by TroyP-4216 »
Hello all.
I am co-owner of an 87 Landseer that will not start from the key switch. When you turn the key, the dash lights up etc but when you turn to start, nothing happens.
We are lucky enough to have some Denning manuals and they refer to a " start safety switch" between the key switch and the start relay. Would anyone happen to know where this is located?
We're hoping it may just be a problem with the start relay though.
thanks in advance
Troy
Re: Denning Landseer - Only Starts from Sub starter
The safety switch is usually on the engine hatch, to prevent the engine being started while someone is working on it. If the door is not closed properly, you can't start it.
On again June 2021
Toolman
Post by Toolman »
There is also a switch on the swinging radiator, catch bolt end. :)
I find it extremely rude that people come on here, ask for advice, but never follow up with feedback on suggestions made.
On again June 2021
TroyP-4216
Thank you for the advice given. The subsequent comment about me being "rude" was not appreciated.
I will certainly provide feedback once I have had a chance to actually investigate. The coach is located interstate from me so I can't just pop out the into the backyard to look at it.
The only switches I have been find initially (at the time of making the original post) were the engine bay light switches on the side hatches.
TroyP-4216
Spent the day investigating a few things.
No sign of any switches on the rear hatch nor on the swing out radiator unfortunately, only on the side hatches.
Found all the fuses etc and all were ok.
Still not sure where the start relay is unless it's called something different.
Have found all the relays in the front fuse panel but none labelled as a start relay.
Will continue investigating but it is very frustrating as everything seems to be working correctly other than it will not start from the ignition key.
Power may go from the key switch direct to the starter solenoid, without needing an intermediate relay.
On again June 2021
TroyP-4216
After changing out the start solenoid/relay (referred to as an Auxiliary Magnetic Switch) I then had a fiddle around with some connectors that I found on the oil pressure switch/sender unit.
The fault was a "dodgy" connection to chassis at this sender unit.
ozbuses
Post by ozbuses »
Well done. Lots of people will learn from this
I recall now that the DDEC system on Detroit diesels had a few such sensors on the engine. A bad connection or loose earth could shut the engine down.
On again June 2021
Maladjusted
Post by Maladjusted »
And do lots of other pain in the A things when you want to get going.
Who bleedin thanked me? I was just doin my job
bjg154
Post by bjg154 »
Any chance of a photo of your machine Troy?
TroyP-4216
Not sure how to upload images sorry.
I think you have to post a link to a separate website possibly.
TroyP-4216
Our work in progress.
DL1201
Return to “New Users/Ask a Simple Question”
