Does this make my car a bus?
Moderator: busrider
Re: Does this make my car a bus?
Not when you select second. It then takes off in that gear. Otherwise good point.
That's interesting! Like a winter mode?
It was my understanding on autos that selecting a gear locked it from going any higher, although I recall a friend with a Volvo 850 reporting theirs behaved similarly depending on which low-gear selection you made.
Yes pretty much. Also recommended for crawling in slow moving traffic. Just give the throttle a tickle and it moves along steady.
Mercedes cars commonly start off in second gear or did.
After going without for well over a month, couldn't help myself #2.
This time I mounted it to the mm as close as this chunky but most accurate model could possibly be.
Was sick of the chunky appearance of the 2000s Chicago Rawhide Hubodometer so I put this on. Looks way more appropriate even if it's for a bus wheel.
I want to put Michael Bublé's face on one and call it a Bublédometer!! You folks will be first to know should I do one.
These stainless steel Allen head bolts arrived by post so I set about grinding just over 1mm off the ends before fitting as they were a tad too long for the bolt bore. I think they look really neat and I decided to see how the only accurate one I have looked. Looks really purposeful with a commercial bent.
Tried this new hubbo on for size.
Would it be possible to make the rear wheels driven electrically with a battery and regen so you can have a four wheel drive if needed ?
Parrahub, an extra option in the public transport menu http://www.parrahub.org.au/
The three Amigos. These are three I have wound up ready to roll to an even number in case I want to sell them.
Here's one for any wheel size - it doesn't work.
