New South Wales - 06/06/10-15/10/10
- ALBION1881
Re: Which Vehicle Is It - New South Wales
Andrew Lower.
- shovelyjoe
- Favourite Vehicle: Mercedes O 500LE
- shovelyjoe
ALBION1881, it's been over three days since you have posted the picture - you must reveal the correct answer now.
- ALBION1881
Here is the answer MO-328.
- busrider
- Favourite Vehicle: Maybe not my car...
And now it's open for anybody to post another picture for this thread...
- Andrew
Which Veolia vehicle is this? Fleet number will do....
The bus is photographed at Sutherland Station after completing its duties on the Shire Free Shuttle, immediately prior to starting a rail replacement shift at about 4am.
Job done.
Job done.
- ALBION1881
- Andrew
That's not the right plate number ALBION. Please note the bus is on city plates (m/o) not the capital MO country plates.
As I mentioned in the post, please use the fleet number to guess. Veolia use fleet numbers and it will save me having to go and check the m/o each time in the fleet lists as I don't remember exactly what that is. It will also save on doubling up the 'highers and lowers'.
Job done.
Job done.
- shovelyjoe
- shovelyjoe
- shovelyjoe
- ALBION1881
674 MO-7317 and I will continue to write a MO plate this way as I had no complaint before as to way its written okay.
- Andrew
You have written the plate incorrectly. MO is how it appears on a country plate. The convention of using m/o for the smaller M and O on a city plate has been used for decades, so I don;t think you should be trying to change it now. Whether or not you have had any complaints is irrelevant. I have seen your statements on the matter before and other people probably haven't bothered to correct you as it obviously wasn't going to sink in.
The bus is higher than 661 and lower than 674.
Job done.
Job done.
- shovelyjoe
You seemed to have had little trouble guessing in fleet numbers as opposed to license plate numbers in the past:ALBION1881 wrote:674 MO-7317 and I will continue to write a MO plate this way as I had no complaint before as to way its written okay.
And, it is up to the picture poster to state whether a fleet number or license plate number is required.ALBION1881 wrote:179 and 180.
- shovelyjoe
- ALBION1881
- ALBION1881
I`ll pass I have lost interest in posting in the NSW sections.
Just out of curiosity...
Is the body on that bus a 210 body or does it have another name?
Sorry for hijacking the thread...
- Trevor 062
- Favourite Vehicle: SUSSEX INLET SB50 HCL
I'll take a punt & say it's a Series 288..If I had the cc body number I could confirm..Cheers Trevor
