ha ha ha Good JobJ.D wrote:Not to out do anyone or anything.
Using Mobi Info Edit (MIE)
- Penguin
- Favourite Vehicle: NSW Rural Fire Service Cat 1
Re: Using Mobi Info Edit (MIE)
All posts are that of my own personal opinion and not that of my employer
Just checking what people think. First attempt, an imitation of a Bristol route.
- El Cubano
- Favourite Vehicle: QR Electric Multiple Unit
Pretty good. Just make sure that all your images are the same. For example on a couple of them all the text moves a bit. The parkway station one is also a little short, but otherwise it looks great!
Regards, Stephen - RailPage Member (scubs) AND PROUD OF IT!
El Cubano Enterprises Transport - QR Citytrain Picasa Web Albums DRGW Trainz Layout by El Cubano Interactive
cant get it on the DER laptop.
- VivalaBuses
- Favourite Vehicle: Scania K310UB, Volvo B7RLE
Mate, just play with it at home (on your home computer as well)!
Time for a new signature!
MIE is not as complicated as it looks once its setup.
But unlike Mobitec ZEdit it can only be used for one set of signs as its designed to be registered to a company!
- Penguin
unless you make different buses and then you can have different setsR-C wrote:MIE is not as complicated as it looks once its setup.
also, how can anyone get a perfect looking CityRail logo for CityRail bus signs in Zedit and MIE?,i suck at it
- VivalaBuses
It's a matter of trial and error (well that's how I did it anyway). I just inserted the Cityrail bitmap into the sign, then edited it til I thought it looked right
Hi there
How did you actually get Mobi Info Edit?
Thanks
Thanks
- VivalaBuses
Hi acbest,
There used to be a link to download a copy of MIE Evaluation version floating around somewhere. But if you just wish to recreate destination signs, then use Mobitec ZEdit which far more easier to use.
Does anyone know where this link is? I already use Zedit, but would love to have a play around on MIE!soulblade wrote:Hi acbest,
and crashes often.soulblade wrote:Hi acbest,
I HAVE A PROB... i made one, and want it as my avatar but how??
how do we save other than .txl?
- VivalaBuses
printscreen each slide, then link together as gif
- Moderator
This is one quick one I've done following what has been posted on here. Its slightly out of line but I'm happy with it as a starter.
- VivalaBuses
Are there any M52s that run to Ryde depot anyway?
- Two-Way
- Favourite Vehicle: Simoco SRM-9000
And why does it have a little M and big 52?
Would you have a look at that K-Whopper hallin' that Wriggle Wagon hes got it to the floor and looking for more!
Posts here are my opinions and thoughts only.
- VivalaBuses
Because that's what they actually look like... saves some desto space too - a big (13x9) M would take two more dots than the little (7x8) MTwo-Way wrote:And why does it have a little M and big 52?
- Two-Way
I'm aware of that, but why did STA make the M small on the M52 desto?soulblade wrote:Because that's what they actually look like... saves some desto space too - a big (13x9) M would take two more dots than the little (7x8) MTwo-Way wrote:And why does it have a little M and big 52?
- VivalaBuses
Perhaps to keep the route number at a standard of 26 dots across, including spacing?
EDIT: Or the M is small because it plays no significance in route number, and its only there for political reasons
- Moderator
For some reason I can't get the route number to work properly. I could do before but can't remember how. It comes up with run time error.
- VivalaBuses
- Moderator
Got the route number working now... Although I still need practicing keeping it inline.
- Moderator
When placing as my avatar it seems to say that it is not within the size limits when in the first sentence clearly states the size which is allowed.
- busrider
- Favourite Vehicle: Maybe not my car...
Maximum dimensions; width: 150 pixels, height: 150 pixels, file size: 97656.25 KiB.
The maximum width is 150 pixels, and that desto is 300 pixels wide. Hence not within the size limits.
