Using Mobi Info Edit (MIE)
New Users (or anyone else) is/are welcome to ask questions in here to which the answers might be obvious to most but you simply don't know yourself or are unsure where to find the answer. You can also ask questions about the working of the forum or anything else you may think of.
Mr OC Benz
Re: Using Mobi Info Edit (MIE)
Post by Mr OC Benz »
busrider wrote:Maximum dimensions; width: 150 pixels, height: 150 pixels, file size: 97656.25 KiB.
The maximum width is 150 pixels, and that desto is 300 pixels wide. Hence not within the size limits.
No I had one done which was 125pixels.
busrider
Favourite Vehicle: Maybe not my car...
Post by busrider »
Seems to work for me...
Mr OC Benz
This is what it comes up with.
The submitted avatar is 125 pixels wide and 18 pixels high. Avatars must be at least 20 pixels wide and 20 pixels high, but no larger than 150 pixels wide and 150 pixels high.
busrider
Post by busrider »
Well then, it's under the minimum requirement... Make it a few pixels taller...
Mr OC Benz
Nathan wrote:Here is a reformatted route 66 desto. Just save it and use as your avatar if you want to. It is within the limits.
Thanks but I prefer to use a more realistic desto type etc...
busrider wrote:Well then, it's under the minimum requirement... Make it a few pixels taller...
Would it work if it was on the exact maximum?
busrider
Post by busrider »
Theoretically, yes... Only way to find out is to try that for yourself.
RailwayBus
Favourite Vehicle: Train or tram.
Post by RailwayBus »
Not to mention he added an "s" onto "Limited Stop" anyway. :roll:
(It might make more sense as "limited stops" but its not the Perth way :P)
busrider
Post by busrider »
He forgot to put the word "via" on its own scroll... The Perth way! :P
Mr OC Benz
busrider wrote:He forgot to put the word "via" on its own scroll... The Perth way! :P
It doesn't need a "via" unless I was to add via Beaufort Street but thats not needed.
RailwayBus
But then he'd also have to add a place that its running via??
Can't just have via without a place. :P
Mr OC Benz
Swan Transit in Perth do... The next slide has where it via's by...
Mr OC Benz
Sweet it worked. Thanks busrider!
hino rg
Favourite Vehicle: Hino RG 197K m/o 9020
Post by hino rg »
soulblade wrote:printscreen each slide, then link together as gif
HOW do you do that
volvo B10M are the best bus ever made
VivalaBuses
Favourite Vehicle: Scania K310UB, Volvo B7RLE
Post by VivalaBuses »
HOW do you do that
Seeing as you have a desto avatar already, I have no idea why you're even asking this question :?:
On your keyboard, there is a button that has "Print Screen" on it. Press that and then open up Paint. Press Ctrl + V, and save that image. Repeat this step until you have all the slides.
Now you crop the individual slides. Open up Microsoft Office Picture Manager and open one of the slides. Click on "Edit Picture..." then "Crop". Move the handlebars so that you are left with the desto slide, then save. Repeat this step for every slide.
Go to Gickr (www.gickr.com) where you can upload those slides where it will make it as a GIF image for you
Time for a new signature!
hino rg
Post by hino rg »
thanks i need someone to show me how do it and i did not make dis one someone eles did i want to make my own 1
National Link
Favourite Vehicle: DVR Locos CL 9-Q and BL 26-E
Post by National Link »
Hi guys,
Sorry to bring this back to the top, but I'm experiencing issues with Zedit 32. After I have programmed all my destos in, I go to use the "Sign Simulation" function, and instead of it opening, it instead brings me back to the programming screen, and reprograms all of my route numbers, regardless of whatever they were. EG 900 would become 903 without being programmed.
Has anyone being experiencing problems similiar to mine?
One Thousand ATDB Posts Can't Be Wrong.
Any views expressed are my own and do not reflect any views of my employers.
VivalaBuses
I haven't experienced what you have described there entirely. It has only happened to me up to returning to the programming screen, but the destos don't get scrambled. Have you tried saving your work, closing ZEdit32, reopening the program, opening your work then using sign simulation? It shouldn't go wrong this way
Daz
Favourite Vehicle: 4964F Heritage
Post by Daz »
Mr OC Benz wrote:The submitted avatar is 125 pixels wide and 18 pixels high. Avatars must be at least 20 pixels wide and 20 pixels high, but no larger than 150 pixels wide and 150 pixels high.
It only took me four months to work out why it didn't work: we were looking too small, not large.
Daz
Transperthpaperbus
Post by Transperthpaperbus »
I am having problems with my MIE program and I have done the repair but it is still giving problem. I have forgotten the web address to download it, so can anybody please in that regard so that I can make sure that I can get a version which is working properly without errors.
Looking to getting more Transperth bus, train and ferry models made up through Transit Graphics.
Currently driving for The Transporter & Buswest Wangara.
bus909
Post by bus909 »
Here mine desto as 900 Liverpool
Liverpool 900.gif (11.49 KiB) Viewed 35165 times
bus909
Post by bus909 »
Would like to share other desto of m92 here:
SUTHERLAND m92.gif (25.74 KiB) Viewed 35065 times
VivalaBuses
Nice attempt, but I've noticed the M of M92 dances around
bus909
Post by bus909 »
Other desto of m90, Which was replaced 900 last year.
LIVERPOOL m90.gif (15.33 KiB) Viewed 35062 times
& m60 which replaced 600 this year.
bus909
Post by bus909 »
soulblade wrote:Nice attempt, but I've noticed the M of M92 dances around
Yeah, But somehow bankstown and padstow with m92 same, but if via lidcombe it dance around..
citadis203
Favourite Vehicle: 4000 Railcar
Post by citadis203 »
I seen destos with signs(eg.cityrail logo)
Can you make a picture into the desto??
Return to “New Users/Ask a Simple Question”
