Bus Driver worksheet
- Favourite Vehicle: Mercedes
Hi there
I have always wanted to know what a typical bus drivers shift/worksheet looks like and what it contains.
I would be particulary interested in recieving an example of one of these from Path Transit, particularly the Mirrabooka area.
However any depot, any area is fine, can somebody help with this.
Cheers
Cheers
- TP 3000
- Favourite Vehicle: MAN 18.310
Re: Bus Driver worksheet
I may just like to let you know that when shifts were changed in Canberra in May, I had a driver ask (on behalf of me) for the old XXX cards. But they were unable to give to them to him as they are a working Government document & are under some "Commercial In Confidence" rule. So using ACTION as an example, every so often the ACT Government tries to tender for the sale of ACTION Buses. Now if the operator of the bus services near Canberra were to see one of these shifts, they would see how ACTION does their running. So that means that Deanes would have an advantage over say Path Transit.
It may be a bit different in WA, but just be aware of that. But if you pick the right driver & they trust you, they may let you view a copy of their shift.
I don't mean to be so strict/mean, but I don't want to see any ACCC investigations into a Transperth contractor, only for ATDB to be brought into it.
But I will be nice & describe what ACTION Shift Cards are like & I suspect Path Transit may be the same. ACTION have the sign on & off times, the total hours that shift covers. If any days off the driver is entitled to. It then lists each run & its timing points. Somewhere in the middle, the breaks will be & where that break is to be taken.
Payback is a bitch, but is fun to watch.
Thanks for that info, totally understandable!
Anyone who can help with my request, it would be great! either have one sent via email or an online example, post.
- PoweredByCNG
Basically the shift sheets contain the name and phone number of the depot, shift number, sign on/sign off times, paid hours, running times (route start, individual timing points, route finish), break times, information relating to destination codes, ETIM codes, and other special instructions (i.e. bus type required, mid-shift bus changeovers, empty running, deviations). Shift sheets are often colour-coded to represent standard (school/uni term) shift, school vac shift, uni break shifts, summer shifts, etc.)
Regards,
Dave
Regards,
Dave
Thanks dave!
Here a Bayswater shift from 2004 from my picture site Transit WA
http://transitwa.fotopic.net/p6096237.html
jase
My Transperth Pic's at http://transitwa.fotopic.net/
LinkArtist Multimedia http://www.linkartist.com.au
Contempt for Humanity http://www.contemptforhumanity.com
Here's what my shift was like for around about 100 years at Bayswater, not that I had any need of a worksheet as it was well & truly memorised. Also, ignore the reference to a meal break, 'twas a rare thing indeed to have one as I was usually out doing change offs.
On the left is the usual shift; on the right is the School Vacs variation:
And it was usually done in the same bus. Here's a photo from the school vacs in October 2002. I've just finished the 1745 886; behind me is the 1740 887 which was on my usual non-school vacs shift. As you can see, I got there first!
Ahhh 6801, never to be seen again
Check out the one minute turn around between the 55 and the 21!!!
jase
Thanks to all who responded,would love a mirrabooka worksheet though
Cheers all
Cheers all
We're still using the Austrix workers like shown in Herbert's post
Thanks everyone for your help, excellent work!
Still would like a Mirrabooka shift if possible.
Cheers!!
Cheers!!
Thanks for putting up those CAT worksheets, busdriver12; I've never seen them before. I thought I had my first MetroBus worksheets, but I can't find them. Likewise, sorry 857panther, I can't find any worksheets with any Mirrabooka running other than 64s.
Jase, as you would imagine, the 1250 21F was known to be a couple of minutes late on occasion. It wasn't originally on my shift, but there was no way of changing things around to split up those two runs on to separate shifts without costing another bus, so I moved it to my shift as it didn't bother me only having a 1 minute turn-around.
Thanks busdriver 12 and herbet, will look forward to seeing what you have, would particularly like Perth-Mirrabooka, and suburban worksheets, girrawheen, koondoola, marangaroo, Alexender heights, kingsway etc
Cheers
Cheers
- Bus-1809
Basically you want a Karrinyup Depot shift.
Karrinyup be cool! or Any Perth - Mirrabooka and through services to the suburbs
- Moderator
Maybe some recent ones would be good as their has been changes to Shift appearances. But with Bayswater Depot there is only a minor difference as on the shift sheets there is no longer NH 405 because Bayswater don't operate them anymore. It will either say Low Floor or it will say Rigid. Also now that Bayswater don't operate NH 405 buses get even more full because the max capacity is 98 on the two O305G(Correct me if wrong) and besides that it is the O405 which carry 68.
- Bus-1809
1 O305G. 662 is the only one at B
857panther: The point I am trying to get across to you is that Karrinyup/Joondalup/Wangara operate the Mirrabooka Services. You can't get a shift for one specific bus station.
- Bus-1809
I'll save you having to do it Phil. Got some old ones (Pre Wayfarer TGX150 ETIM Roll out (All but one)) here that Drivers have given me. 857 Panther, the Wangara shifts have HEAPS of Mirrabooka Running on thembusdriver12 wrote:I still have a lot of spare paper left over from my Path days and if I come across one with some Mirrabooka running on it will scan and post here
***PLEASE NOTE: THESE SHIFTS ARE NOT CURRENT. THERE HAS BEEN AT LEAST 4 SHIFT CHANGES SINCE THESE WERE VALID***
1st up is Shift 3891 which is the Afternoon Supervisors Shift at Mirrabooka B/S (School Vacaions) This should be green but the dimwit operating the scanner had it on the wrong settings The Next one is a Saturday Shift. No. 3302 And this last one is one for actually!. Shift 6830 from their depot. I think they may have even done this one a few times. Notice how each shift has a different Colour?
White = Weekdays (School Term)
Green = Weekdays (School Holidays)
Blue = Saturdays
Yellow (Sometimes Pink) = Sundays (I think these change between Summer and Winter because of runs like the 408?)
Hope this helps.
thanks everyone
- Mandurahbus
- Favourite Vehicle: Hyundai's!!!,Holden & 1214
i hope ive got this right as im using mandurah shifts as a example=
40xx= full shifts
41xx & 42xx=short shifts
43xx & 44xx= saturdays
45xx= sundays and public holidays
46xx= school shifts
70xx= full shifts school holidays
71xx & 72xx= short shifts school holidays
9xxx=rail replacement,special events
40xx= full shifts
46xx= school shifts
The Mercedes Benz O305 & O305g Preservation Group is on Facebook
Robert Bus Service: Proudly serving the Mandurah area for 18years!!!!
Robert
Robert
- Bus-1809
PATH:
x1xx - Weekdays Earlies and Spread
x2xx - Weekdays Twilights and Nights
x3xx - Saturday Day
x4xx - Saturday Twilights and Nights
x5xx - Part Time (Morley Only)
x6xx - Circle Route (Morley Only
x7xx - Public Holidays with Saturday Circle Route Timetable
x8xx - Special Duties (Wash, Starter, Fuelling, Supervisor, Cleaning etc..)
x900 - x949 - Sunday Days
x950 - x979 - Sunday Twilights and Nights
x980 - Sunday Fuelling
9xxx - Special events.
x3xx - Saturday Day
- renaultartic
- Favourite Vehicle: Merc 339 and Renault Artics
First number on shifts at PATH indicate which depot it's running from also, i.e- 1xxx = Karrinyup, 2xxx = Joondalup, 3xxx = Wangara, 4xxx = Morley, 5xxx = Two Rocks, 6xxx = Bayswater, 7xxx = Nowergup and 9xxx = Special Hire.
Leigh.
Leigh.
Purring at City CATs. Driver of 635 buses over a 20 year period.
- Bus-1809
Thanks Renaultartic. I didn't put that up because not being an employee of PATH Transit, I'm pushing the boundaries by posing the shifts.
- Moderator
Post Removed...
