Tasmania - 03/02/2011-30/07/2011
- Tas Bus Nut
- Favourite Vehicle: Mercedes Benz O303
- Bedford-29
Re: Which Vehicle Is It - Tasmania
leyland clippers wrote:#218
Echo.... echo.... echo... Lower.... lower... lower.....Tas Bus Nut wrote:#218
Already lower than 219Bedford-29 wrote:221
- Tas Bus Nut
Sorry, Frosty's guess hadn't come up on MY computer when I posted.yoda wrote: Echo.... echo.... echo... Lower.... lower... lower.....
My apologies oh wise one Try ONLY one left then, which is #216
You must have been looking at it and thinking for a whileTas Bus Nut wrote:Sorry, Frosty's guess hadn't come up on MY computer when I posted.
Higher than 216, which leaves....
... to be spot on!Cole wrote:217 ?
Number of the Scania, not the Volvo ta
- Tas Bus Nut
Try #147
- Tas Bus Nut
Good point Cole. #181 doesn't have a Scania badge, so therefore it cannot be #147.
Scratch that guess yoda. Need to re-evaluate
Tas Bus Nut wrote:Try #147
And you're re-evaluation is.... going to be wrong anywayTas Bus Nut wrote:Good point Cole. #181 doesn't have a Scania badge, so therefore it cannot be #147.
Cole has it first up... even though I hid the AOACole wrote:181
Couldn't upload last night, so here goes.
I am after the identity of the Volvo furthest to the right.
For those of you unsure which is the right hand side, it is ------>
Bonus points will be awarded for guessing the other vehicles in shot.
- leyland clippers
- Favourite Vehicle: Ansair buses & coaches
From Right to Left #719, #710, #722
Hobart,The Way Life Should Be
- stevegj52
- Favourite Vehicle: Volvo Bus & Coaches
Hmmm all 3 are Mk 1 so I will say 706 709 711 If I have all 3 correct then a slab will be fine yoda
Volvo B8R,green efficiency built in
Left to right 708 710 707 ????
Proudly Supporting the Gold Coast Suns.
- Tas Bus Nut
L > R - #707 , #710 , #705
They are all Mk1's, but sorry no slabstevegj52 wrote:Hmmm all 3 are Mk 1 so I will say 706 709 711 If I have all 3 correct then a slab will be fine yoda
NopeCole wrote:Left to right 708 710 707 ????
NopeTas Bus Nut wrote:L > R - #707 , #710 , #705
- Tas Bus Nut
L > R #705, #710 & #707
NopeTas Bus Nut wrote:L > R #705, #710 & #707
- Tas Bus Nut
OK. The original Q was, what is the # of the bus on the right. I guess #711
Exactly! The others are just a bonus...
Higher than 711
Higher than 711
- Tas Bus Nut
