L.H. Side of steer column on floor is 2" black button under a 4" spring loaded flap. Can't trace the wiring as it goes directly into the loom and can't see the wire code colors either! Hope someone knows what it is
Thanks Fellas. An answer would be helpful. the 0305 runs well but has that rear end "Bang" when going through the gears. I love the bus though. I bought her in 2009 No 2190 from STA in Brookvale.............Have a good day all
Cliffy 0
'79 merc 0305..L.H. side of steering column is a 2" electric
Re: '79 merc 0305..L.H. side of steering column is a 2" elec
That button was for the driver to alert the radio room that there was a problem.
The bang in the back may be a diff problem.
- mrobsessed
- Favourite Vehicle: AEC Reliance
I have a funny story about 2190 when it was at Waverley. I'll PM you.
- Doc68
- Favourite Vehicle: Technics sl1200
???????mrobsessed wrote:I have a funny story about 2190 when it was at Waverley. I'll PM you.
'GM 2strokes, still the most efficient engine ever developed for converting fuel into noise'.
Food has replaced sex in my life now I can't even get into my own pants
The bang in conjunction with gearchanges could be that the transmission is shifting too harshly thus sending a shock load through the driveline, the rear axle could be at fault as well but my experience would more so suggest the shifting issue with the transmission.
Peta.
Peta.
