You continue to peddle your false comparison of journey times of the metro with the existing slowed down Sydney Trains timetable, without acknowledging the improvements which will be made with the digital signalling and ATO upgrades. Comparisons with the Paris RER are also irrelevant.tonyp wrote: ↑Fri Jan 12, 2024 5:25 pmThe throughput of RER A is great, because they have so many people to move (at least 300 million a year, which is like the entire Sydney Trains system!), but the 2 minute headways don't last too long before they drop back a little for breathers and/or miss a couple of stops to catch up. It's a tough gig and they don't manage it with ease, but the French railways are very capable.
However, it's the journey time we're discussing and in that regard, the Paris operation is closer to Sydney Trains than Sydney Metro. Indeed it shows that automatic operation won't speed up a heavily-used double deck service that much.
I've done comparisons in the past on the basis of similar pretty straight and level track profiles, same distance, same or similar number of stops. Here are a couple of the results. Bear in mind that the Sydney suburban examples typically include long express sections, whereas the Sydney Metro and RER A are all stops. So the Sydney suburban services have differing stopping patterns, but I've chosen examples that have the same number of intermediate stops as the other two systems.
58 km
Sydney suburban Emu Plains- Central: 21 stops, 75 minutes, average speed 46 km/h.
Paris RER A Marne-La-Vallee - St-Germaine: 22 stops, 72 minutes, 49 km/h.
Sydney Metro: Tallawong-Marrickville: 20 stops, 62 minutes, 57 km/h.
63 km
Sydney suburban Emu Plains- North Sydney: 23 stops, 86 minutes, 44 km/h.
Paris RER A Boissy-St-Leger - Cergy-Le-Haut: 24 stops, 80 minutes, 47 km/h.
Sydney Metro Tallawong-Canterbury: 23 stops, 68 minutes, 58 km/h.
So RER A's strength is its ability to move large patronage at close frequency, but with a pretty ordinary journey time. RER A represents what Sydney's suburban operation strives to be with more automation and better signalling, yet it doesn't achieve much improvement in journey time. This suggests to me that this is an inherent weakness of double deck trains, something that an average blind freddy and his dog has known for years but somehow doesn't find its way past the rose-coloured glasses of double deck enthusiasts. Double deckers have their role on long distance semi-express services where they don't have to stop so much. For stopping services, they're not so good.
We've struck the right balance with Sydney Metro - much higher capacity, capable of 2 minute headways and with an average speed at least some 10 km/h higher than that of the other two operations. By the way, this also provides an insight into the other question here - will higher speed limits improve journey time? The metro is theoretically the tortoise here, limited to 100 km/h, compared to the hares on suburban at 115 and RER A at 120. Isn't there an old fable about the hare and the tortoise? As I keep saying like a broken record, it's average speed that's significant.
Why would the government spend millions and ultimately billions on upgrading the Sydney Trains network with digital signalling and ATO if there is no benefit? It would cost significantly more to convert existing lines to metro for only marginal benefit, not to mention the disruption which is yet to be experienced on the Bankstown Line conversion, let alone duplicating lines with metro. It wouldn't stack up on a cost/benefit analysis.
I might add that I'm not a DD purist, but just accept the bleedingly obvious fact that it's what we have at present and is likely to be for many decades to come on the existing network. There may be an opportunity to introduce compatible SD trains on some inner city lines in the future, which had been proposed on the existing network before the segregated metro system was prioritised. I support new metro lines in the inner city regions servicing areas without an existing rail service and that includes cross regional metro lines.
You have ignored my earlier post about "average speed", in again failing to acknowledge the inherent acceleration/deceleration capability of the latest suburban rolling stock, which has been geared down, and can potentially be upgraded to its original design specification which is close to the performance of the metro stock, dwell times aside on the busiest stations in the CBD. In any event, dwell times should be improved when the metro line takes interchange pressure off Town Hall in particular.
