Continuing from here
All IT systems have their limits. While they are built with a degree of flexibility in them, a fix is not always as simple as it may seem. There may also be an internal control that only allows files from certain sources to update certain tables, which is a good control to have 99% of the time, but does cause the odd problem.Merc1107 wrote: ↑If that is seriously an issue in 2022, that some software used by TfNSW is so limited it cannot generate a timetable where more than one operator is involved, I'm speechless.
Without knowing the details of the system, probably a case of the most recent file overriding the existing data meaning only information appearing for one operator. The work around would be to combine the csv files from the two operators before uploading. But obviously this may require manual intervention to what is an automated process.Aurora wrote: ↑The pdf files should be able to be manipulated or configured by Transport in such a way as to make it work. Not that difficult in 2022, except for mediocrity and/or bureaucracy getting in the way of making progress.
