HISTORY of ADELAIDE - BUS, TRAIN & TRAM ROUTES
T3331
Favourite Vehicle: 3331
Re: HISTORY of ADELAIDE - BUS, TRAIN & TRAM ROUTES
Post by T3331 »
Sorry, the link should be fixed now and hopefully you can open it.
https://www.google.com/maps/d/edit?mid= ... sp=sharing
Lt. Commander Data
Favourite Vehicle: Scania L94UB
Post by Lt. Commander Data »
T3331 wrote: Thu Oct 01, 2020 8:17 am Sorry, the link should be fixed now and hopefully you can open it.
That map is correct, it’s interesting that we have a similar loop again today. If I get some spare time over the next few weeks I’ll happily share the other Mt Barker Loop (route 846, c.2000-2002), and the various routes that buses have taken though Mt Barker (the 840 used to go further than the railway station)
leftyandy76
Favourite Vehicle: Volvo B10M artics
Post by leftyandy76 »
Lt. Commander Data wrote: Thu Oct 01, 2020 6:58 pm
They'll be interesting to see thank you.
softgrow
Post by softgrow »
Thanks for the map. Would be nice to have bubbles for 400m walking distance around each stop overlaid :) (Can be done in a GIS package, use OpenStreetMap for roads)
BusFan23
Post by BusFan23 »
Does anyone know any history of route 601 and 605? (And maybe why 602-604 are missing). Thanks
bigrobbo
Location: Mainly grumpy and pacing around Mawson Interchange
Post by bigrobbo »
BusFan23 wrote: Fri Dec 25, 2020 5:56 pm Does anyone know any history of route 601 and 605? (And maybe why 602-604 are missing). Thanks
Gee....you ask about one of the most re-numbered and re-routed services I know of!
I suggest that you search this thread for Routes 609 and 610 to start with. 609 is now today's 601 from Marion to Blackwood.
I do not know dates - but 609 was renumbered 739 at some point, and there was (I think) a 729 scheduled from the city. Both services went to Blackwood. A new route, 728, was introduced to go straight up Sheperds Hill Rd.
Then, at another time this century, the 739 was renumbered 601. At the same time the 197/198 were combined with todays 600/601. Initially, the new 600/601 started at Henley Beach, then cut back to Glenelg, and then cut back to Marion.
The section between Aberfoyle Hub and Old Reynella has been added on , taken off, and then added back on again.
My suggestion is to use the Search on this thread for routes 609,610, 739 and you should be able to piece together the history, as it is well documented.
bigrobbo
Post by bigrobbo »
Though I can quickly tell you about why the 601 started at Henley Beach.
Many years ago there was a cross-suburban route which went from Port Adelaide to Glenelg (and eventually Marino) (33) and return (34). The Glenelg to Marino section was originally numbered 665. (I think). In the 1980's this was renumbered 340.
While it had a few changes around Port Adelaide over time, the 340 ran from Henley Beach to Marion Shops via the current 300 route. A variant was introduced, 345, which went to Flinders Uni.
Sometime in the 2000's, the 340/345 were discontinued and the route split up. Initially, the Henley Beach to Flinders University section was covered by route 110. City to Flinders Uni via Grange Road (current 110) and then the old 345 route to Flinders Uni. This route was designed to connect with the current H30 at Henley Square so passengers could travel to West Lakes.
Eventually the 110 was cut back to Henley Square and through routed with the 600/601. When the 300 was introduced, the 600/601 was cut back to start at Marion.
There was also a period of time that the 600/601 was through routed with the J7.
Just for interest, the last variant of the 340 has been split up as follows
- Port Adelaide to West Lakes was renumbered 350 and has been discontinued. Part of this route is covered by todays 371/372.
- West Lakes to Henley Beach does not exist. The route along Military Rd is covered by today's 112/371/372.
- Henley Beach to Marion is covered by 300.
- Marion to Marino is covered by 640. The bus has been re-routed through Marino and now terminates south of Marino Railway Station. The original Terminus was Marino Rocks Railway Station. The last 340 to run took Diagonal Rd to Seacombe Rd, and not Marion Rd as the 640 does today,
Lt. Commander Data
Good work bigrobbo. There were a few 729F services, they operated from the City via South Rd, then Shepard’s Hill Rd and the Eve Rd loop to Blackwood. Similarly, the 728F ran direct via Shepard’s Hill Rd.
These then became the 217 and T217, and are now covered by the G30F.
I might just add that before the 600/601 were extended to Aberfoyle Hub and all Reynella, this section was the 695, 696, 697, 698, and 699.
695- today’s 605
695- today’s 601 between Blackwood and Aberfoyle Hub
697- Blackwood to Aberfoyle Hub via Main Rd and Manning Rd (so 601 through Coromandel Valley, 600 through Aberfoyle Park)
698- today’s 600 between Blackwood and Aberfoyle Hub
699- today’s 600/601 between Aberfoyle Hub and Old Reynella
Prior to this, routes 197 and 198 covered this area. Operating from the City via Unley Rd and Main Rd to Blackwood, then
Route 197 followed the above listed 697
Route 198 followed the above listed 698
These routes both then continued to Old Reynella.
As for dates, without checking relevant sources I’d put approximate dates at:
609 renumbered 739 ~ 1988
739 to 601 (and 738 to 601) was 2008 I think
340 and 345 were broken up in 2006
728/729 to 217 would have been between 2006-2008
217 to G30F in 2009
197/198 to 695-699 between 2005-2007
695-699 to 600/601/605 in 2009
The Phonj
Favourite Vehicle: MAN SL202, PMCSA body
Post by The Phonj »
I seem to have a recollection of a route that travelled from Aberfoyle Hub and did a loop of Oakridge Rd and Homestead Dr before returning to Aberfoyle Hub during the 69x days - although the route number escapes me right now.
Lt. Commander Data
The Phonj wrote: Mon Jan 04, 2021 4:55 pm I seem to have a recollection of a route that travelled from Aberfoyle Hub and did a loop of Oakridge Rd and Homestead Dr before returning to Aberfoyle Hub during the 69x days - although the route number escapes me right now.
Was it the 690? Ran during the day and morning with the RZ19 at nights?
Tonsley213
Post by Tonsley213 »
Anyone know the history of route 109?
doyle
Post by doyle »
Any information about old routes 3 and 4 Addison and Hanson rds in particular destinations numbers and short working numbers
leftyandy76
doyle wrote: Sat Jan 16, 2021 12:55 am Any information about old routes 3 and 4 Addison and Hanson rds in particular destinations numbers and short working numbers
I'll do my best here, but there will be other's who'll know more than I do:
Route's 3 & 4 (which became Route's 258 & 259) followed the same route to Arndale Shopping Centre as the Route 253 does today, then; ( I won't include the through route numbers so as not to confuse you)
Route 3 -- Arndale Shopping Centre, First Ave, Hanson Rd, Torrens Rd, Addison Rd, Grand Junction Rd, Commercial Rd to Port Adelaide
Route 4 -- Arndale Shopping Centre, First Ave, Hanson Rd, Grand Junction Rd, Commercial Rd to Port Adelaide:
The short workings were:
3A -- From the City to Cheltenham via Torrens Rd; From Pt Adelaide to Cheltenham via Addison Rd
3B -- From the City to Kilkenny (Arndale Shops) via Torrens Rd; From Pt Adelaide to Kilkenny via Addison Rd
3C -- ???
3D -- From the City to Grand Junction Rd (assuming it terminated at Port Depot); From Port Depot to Kilkenny or the City via Addison Rd
4A -- From the City to Croydon via Torrens Rd; From Pt Adelaide to Croydon via Hanson Rd
4B -- From the City to Kilkenny via Torrens Rd; From Pt Adelaide to Kilkenny via Hanson Rd
4C -- From the City to Athol Pk via Kilkenny & Hanson Rd
4D -- From the City to Junction Rd (assuming Port Depot) via Kilkenny & Hanson Rd; From Port Depot to the City or Kilkenny via Hanson Rd.
If there's anything that's missing from here, feel free to fill in the blanks. Just as if I've made any mistake's, please correct them.
TT
Favourite Vehicle: Anything without SCANIA badge.
Post by TT »
I can remember 3R services, via the 3 route but terminating at Cheltenham racecourse on race days.
And before Arndale and for the first few years of Arndale buses didn’t use First Avenue. Just Torrens Rd, then right at Hanson Rd for 4 route and straight for 3 route. Even when the 100 route (Circle Line then) commenced operation the start and finish was on Torrens Rd in front of Arndale, both sides of road (north for clockwise and south for anticlockwise). It’s not that many years ago that the long line of bus shelters were removed from the northern side of Torrens Rd in front of Arndale.
doyle
Post by doyle »
Thank you both :D
leftyandy76
doyle wrote: Sat Jan 16, 2021 11:52 pm Thank you both :D
You're welcome
doyle
Post by doyle »
Hello again I'm seeking more information about old routes pre 88 this may/is a big ask but I'm after information from
routes 5 right through to routes 34 in particular destinations numbers and short working numbers
Rather than asking route by route I thought one big list if at all possible
I appreciate any help that may be provided and understand if this is way too much
Thank you
leftyandy76
doyle wrote: Mon Jan 18, 2021 2:22 pm Hello again I'm seeking more information about old routes pre 88 this may/is a big ask but I'm after information from
Thank you
I'll do my best here, but if anyone can help fill in the blanks, it will be much appreciated
5 -- Belair Athol, Prospect Rd (current G10 terminus)
5A -- Prospect, Hillsdale St
6 -- Gepps Cross, Main North Rd
6A -- Enfield, Ragless Ave
7 -- Northfield, Grand Junction Rd
7A -- Clearview, Folland Ave
7B -- Ingle Farm Shopping Centre, Beovich Rd
7C -- Walkerview North, Hampstead Rd/North East Rd
7D -- Gilles Plains, Blacks Rd
7E -- Windsor Gardens, Lyons Rd
7G -- Ingle Farm West, Naomi Ave
7H -- Ingle Farm, Blaxland Ave
8 -- Marden (current Route W91 terminus)
8A -- Hillcrest Hospital
9 -- Paradise, Lower North East Rd (before being moved to Derancourt by 1987)
9A -- Glynde, Payneham Rd
9C -- Newton, Montacute & Stradbroke Rd
9D -- Athelstone, Quondong Ave
9F -- Athelstone (Coulls Rd) via Lower Athelstone Rd
9G -- Athelstone (Coulls Rd) via Graves St
9H -- Paaradise Interchange (by 1987)
10 -- Rostrevor (current Route H33 terminus)
10A -- Firle, Reid Ave/Fisher St
10B -- Rostrevor College, Moules Rd
10C -- Rostrevor, Cnr Morialta Rd/Stradbroke Rd
10D -- Rostrevor, Koonunga Ave
11 -- Magill (current Route 106 terminus)
11A --Tranmere, Glynburn Rd
12 -- Wattle Pk (current Route H23 terminus)
12A -- Kensington, Gurrs Rd
12B -- Rosslyn Pk, Primrose Tce
13 -- Stonyfell (current Route 141 terminus)
13B -- Burnside (current Route 142 terminus
14 -- Beaumont (current Route 147 terminus)
15 -- Glen Osmondm Gilles Rd
15A -- St Georges, Portrush Rd
16 -- Glen Osmond (current Route 861 terminus)
17 -- Springfield, Fullarton Rd (then extended to Mitcham by 1987)
18 -- Kingswood
19 -- Mitcham, Albert St
19B -- Mitcham Shopping Centre (current Route 171 terminus)
19C -- Torrens Pk, Kays Rd
20 -- Clapham (current Route 200C terminus)
20A -- Unley, Greenhill Rd/Unley Rd
20B -- Hathorn, Denning Tce
20C -- Colonel Light Gardens, East Parkway
21 -- Colonel Light Gardens, Stop 18 Goodwood Rd
21A -- Goodwood (Cross Rd)
21B -- Clarence Park
21C -- Panorama, Grandview Dr
21D -- Flinders University
21E -- Bedford Pk, Sturt Rd
23 -- Seacliff, Wheatland St
23A -- Richmond, South Rd/Anzac Hwy
23B -- Glandore, Marion Rd/Anzac Hwy
23C -- Camden Pk, Morphett Rd/Anzac Hwy
23D -- Glenelg, Gordon St originally then shifted to Augusta St.
23E -- Glenelg North via Anzac Hwy
23G -- Glenelg, Gordon St, then shifted to Moseley St
23J -- Hove via Anzac Hwy
23L -- Warradale via Anzac Hwy
23M -- Marion S/Centre (current Route 263 terminus)
24 -- Somerton Pk via Richmond Rd, South Rd, Anzac Hwy
24A -- Richmond via Richmond Rd, South Rd to Anzac Hwy
24B -- Glandore via Richmond Rd, South Rd, Anzac Hwy to Marion Rd
24C -- Camden Pk via Richmond Rd, South Rd. Anzac hwy to Morphett Rd
24D -- Glenelg, Gordon St via Richmond Rd, South Rd. Anzac hwy
24E -- Glenelg Nth via Richmond Rd, South Rd. Anzac hwy
25 -- Somerton Pk via Anzac Hwy, Stonehouse Ave, Morphett Rd
25C -- Camden Pk via Anzac Hwy, Stonehouse Ave, Morphett Rd
25D -- Glenelg, Gordon St via Anzac Hwy, Stonehouse Ave, Morphett Rd
25E -- Glenelg Nth via Anzac Hwy, Stonehouse Ave, Morphett Rd
26 -- Somerton Pk via Richmond Rd, South Rd, Anzac Hwy, Stonehouse Ave, Morphett Rd, Anzac Hwy
26C -- Camden Pk via Richmond Rd, South Rd, Anzac Hwy, Stonehouse Ave, Morphett Rd
26D -- Glenelg, Gordon St via Richmond Rd, South Rd, Anzac Hwy, Stonehouse Ave, Morphett Rd, Anzac Hwy
26E -- Glenelg Nth via Richmond Rd, South Rd, Anzac Hwy, Stonehouse Ave, Morphett Rd, Anzac Hwy
By 1987 the Route 26E became the Route 26G & Route 26 was terminated at Marineland
27 -- Richmond, Dover St
27B -- West Beach, Atlantic Ave
27C -- Marineland
28 -- Grange, Jetty Rd
28A -- Torrensville, Marion Rd
28B -- Lockleys, May Tce
28C -- Henley Beach, South St
28D -- Henley Beach North, North Tce
28G -- West Lakes S/Centre (current Route H30 terminus)
28H -- West Lakes S/Centre via Henley Bch Rd, Seaview Rd, Military Rd, West Lakes Blvd
28J -- Pt Adelaide via Route H30 to West Lakes S/Centre, then West Lakes Blvd, Military Rd, First Ave, Sansom Rd, Bower Rd, Carlisle St, Hart St, St Vincent St, Commercial Rd
28K -- Pt Adelaide via Route H30 to Grange Station, then Military Rd, West Lakes Blvd, WEST LAKES S/C, West Lakes Blvd, Frederick Rd, Webb Sr, Port Rd, Commercial Rd
28L -- Henley Beach South (Current Route H33 terminus)
29 -- Grange, Grange Station
29A -- Findon, Crittendon Rd
29D -- Queenstown, Broad St
29G -- West Lakes S/Centre via Frederick Rd (current Route 110 terminus)
29H -- West Lakes S/Centre via Trimmer Pde (current Route 115 terminus)
29J -- Pt Adelaide via Frederick Rd. West Lakes S/C, West Lakes Blvd, Bartley Tce, Carlisle St, Hart St, St Vincent St, Commercial Rd
29K -- Seaton, Pedlar St/Tapleys Hill Rd, this was extended to Port Adelaide & followed the current Route 118 from the City to Pt Adelaide (commenced 1986)
29L -- Delfin Island via Crittendon Rd, Tapleys Hill Rd, West Lakes Blvd & W/Lakes S/C (commenced 1986)
30 -- Semaphore via Port Rd, Commercial Rd, St Vincent St, Hart St, Military Rd, South Tce, Esplanade, terminating at the west end of Semaphore Rd
30B -- Alberton via Port Rd from the City (Port Depot), from Semaphore & from Largs Bay
30C -- Pt Adelaide via Port Rd or from Semaphore & from Largs Bay
30D -- Largs Bay via Port Rd, Commercial Rd, St Vincent St, Nelson St, Semaphore Rd, Woolnough St, Military Rd, Harrold St, Esplanade, terminating at the west end of Jetty Rd
31 -- North Haven via Port Rd, Commercial Rd, St Vincent St, Nelson St, Semaphore Rd, Fletcher Rd, Military Rd, Strathfield Tce, Victoria Rd, Osborne Rd to Lady Gowrie Dr
31B -- Alberton from North Haven or Osborne
31C -- Port Adelaide from North Haven or Osborne
31E -- Osborne via via Port Rd, Commercial Rd, St Vincent St, Nelson St, Semaphore Rd, Fletcher Rd, Military Rd, Strathfield Tce, Victoria Rd to Sir Keith Smith Dr
32 -- Glenelg via current Route 167
32H -- Glenelg via current Route 168
33 -- Port Adelaide to Marino via Commercial Rd, St Vincent St, Carlisle St, Hart St, Bower Rd, Sansom St, First Ave, Military Rd, Grange Rd, Seaview Rd, Burbridge Rd, Davis St, Ingerson St, Indian Ave, Northern Ave, Cambridge Ave, Rio Vista Ave, West Beach Rd, Military Rd, Patawalonga Frontage, King St, Adelphi Tce, Anzac Hwy, Gordon St, Jetty Rd, Moseley St, Pier St, Diagonal Rd, Sturt Rd, MARION SHOPPING CENTRE, Sturt Rd, Diagonal Rd, Seacombe Rd, Brighton Rd, Scholefield Rd, Kauri Pde, Cygnet Tce, Singleton Rd, Cameron Ave, Bandon Tce, Jervois Tce, Newland Ave, MARINO.
Route 34 is the reverse of the Route 33
34G -- Marino to Glenelg via MARINO R/S, Newland Ave, Sherlock Rd, Scholefield Rd, Brighton Rd, Seacombe Rd, Diagonal Rd, Sturt Rd, MARION S/C, Sturt Rd, Diagonal Rd, Brighton Rd, Jetty Rd, Moseley St, GLENELG
34M -- Marino to Marion S/C via Newland Ave, Sherlock Rd, Scholefield Rd, Brighton Rd, Seacombe Rd, Diagonal Rd, Sturt Rd, MARION S/C,
These route's are from the timetable dated 11/1987
35 -- Semaphore; from Glanville Rail Station, Causeway Rd, Semaphore Rd to the terminus at The Esplanade.
TT
Post by TT »
Thanks for the extensive detailed information leftyandy76. A few additions/corrections. My memory, happy to be corrected.
32 (via 167 or 168?) originally finished at Novar Gardens, near corner of Pine Av and Bonython Av. Through-routed with route 16 to Glen Osmond. First routes with full-time one man operation. 32 extended to Glenelg (still as route 32) in early 1970s.
28 went via Henley Beach Rd and Seaview Rd, then Beach St to terminus in Military Rd just before Jetty St. Returned to city via Jetty St and Seaview Rd.
28E finished on Trimmer Parade, first extension of 28 just before West Lakes opened. Via Military Rd to Trimmer Pde terminus, to city via Fort St (H30).
29 route was to Kirkcaldy (then a suburb) via George St, South Rd, Grange Rd, left Seaview Rd, left Reedie St to
terminus in Military Rd just north of Reedie St. Through routes with 10 and 11 routes. Not until late 1970s did it terminate Grange Stn. That was via Seaview Rd and Terminus St to Military Rd. The 28H 28J 28K routes also originally went via Seaview Rd and Terminus St to West Lakes.
And in 1960s 28 through routed with 12 to Kensington Gardens (Taylor Tce, Primrose Tce outside then Norwood High School). The H23/H24 terminus at Auldana you refer to only opened in early 1980s as Auldana established.
I thought one of the Kensington Rd routes terminated at the current Wattle Pk H22 terminus on Penfold Rd but not sure on that one.
jibb
Post by jibb »
Originally Route 13 ran all the way up Kensington Road,and turned right at Penfold Road to the current H22 terminus.
When the H22 operated from its current Wattle Park terminus,the 13 became 141 and only went as far as Hallet Road,turned right unril it reached the terminus at Greenhill Road.
Just as a matter of interest the Burnside route and terminus has remained the same since trolley buses ceased in 1963.
Was 13B now 142.
The Phonj
Post by The Phonj »
TT wrote: Wed Jan 20, 2021 2:48 pm 32 (via 167 or 168?) originally finished at Novar Gardens, near corner of Pine Av and Bonython Av. Through-routed with route 16 to Glen Osmond. First routes with full-time one man operation. 32 extended to Glenelg (still as route 32) in early 1970s.
32 to Novar Gardens via Marion Rd and Mooringe Ave (167) was only extended to Glenelg in 1980, as a part of newtork reforms involving former MTT and private routes. Route 32H introduced at this time.
leftyandy76
Thanks for the information TT and jibb
doyle
Post by doyle »
That's excellent this information is very much appreciated, I moved about 8 years ago and subsequently lost misplaced all my timetables and a September 1975 Adelaide public transport map I was and still am devastated
Thank you all for your help time & collective knowledge
Doyle
odie8888
Post by odie8888 »
interesting about the Athelstone services.later on we had the 576 and 577 for people who didn't need or want montacute and payneham rd to the city as that was covered by the 179 and was formerly the 176 and 177.the new services worked out faster than the old.
Return to “Discussion - Adelaide / SA”
