Hi Guys,
Which route will I most likely find a Hillsbus Scania L94UB? I am referring to the Dural L94UBs 12.5Ms not the 14.5Ms
Thanks in advance
Re: Which route will I most likely find a Hillsbus Scania L94UB?
The routes you would most likely find these Scanias on the 635,637-641 witch are the services that start at or go though Castle Hill and then run along Old Northern road to Dual and beyond these routes are known as the Dural local routes
There is also Dural local routes that start at Becroft and Rouse Hill witch are the 635 and the 641
