January 2019 service changes
Re: January 2019 service changes
Postby Eurostar » Mon Jan 21, 2019 5:12 pm
I wonder if some of these cuts are being done to free up money for the extras for the Flinders Railway Extension, now they have included in the plan stairs and lift on both sides of Main South Road as well as the original proposal of just ramps.
Next station is Victoria Square. Change here for all trains.
Eurostar
Has thanked: 15 times
Been thanked: 24 times
Favourite Vehicle: XPT
Postby TA3001 » Mon Jan 21, 2019 7:15 pm
I reckon the 224 between Salisbury and Elizabeth should be scrapped, with 430s turning into 423s that traverse Salisbury Highway and terminate at Mawson. The 560 is essentially a duplicate of the existing 224 service anyway, and they ran almost simultaneously for well over a decade until recently.
224s could run on weekends from Mawson interchange to Elizabeth to keep the frequency at 30 minutes, but 3 buses every 30 minutes in each direction serving John Rice Avenue is just a waste of resources.
TA3001
Has thanked: 51 times
Been thanked: 84 times
Favourite Vehicle: Hills B58. In service - 880
Postby Eagle Eye » Tue Jan 22, 2019 7:45 am
The Port Road Go Zone has been removed from the 150 & 155-157 timetable maps.
Eagle Eye
Has thanked: 121 times
Been thanked: 151 times
Postby Mike M » Tue Jan 22, 2019 9:21 am
Eagle Eye wrote:The Port Road Go Zone has been removed from the 150 & 155-157 timetable maps.
The Port Road now has what can only be described as a rather odd 15-30 minute service interval pattern between the peaks on Monday to Friday.
A similar thing has happened on the parallel rail line services from Adelaide to Woodville which now run at 10-20 minute intervals while they continue to run every 15 minutes in the opposite direction.
I'm sure there is some logic to all of this!
Mike M
Has thanked: 10 times
Been thanked: 61 times
Postby jibb » Tue Jan 22, 2019 9:48 am
Quite a substantial overhaul of 150-155-157 weekday daytime timetable.
jibb
Has thanked: 521 times
Been thanked: 221 times
Postby Eagle Eye » Tue Jan 22, 2019 4:23 pm
Mike M wrote:I'm sure there is some logic to all of this!
Looks like the number of consists for the Grange line can be reduced at interpeak & night time due to the reduced layovers at Grange. Taking one consist out of the mix will reduce diesel use if nothing else.
Eagle Eye
Postby Eurostar » Fri Jan 25, 2019 2:39 pm
From Sunday 224s will mainly be feeders which quite possibly will mean Pooraka recieves more articulated buses to do 222s
Eurostar
Postby Eurostar » Sat Jan 26, 2019 6:46 pm
Just thinking that the T500 worked better than the 502. I mean at least with the 206, the bus had good patronage especially at night, compared to the 502 which looks close to empty at night
Eurostar
Postby Eurostar » Tue Jan 29, 2019 12:02 pm
Salisbury Council should just buy up the shops on Old John Street, demolish them, widen the road so buses can use John Street
Eurostar
Postby thedom » Tue Jan 29, 2019 12:51 pm
Eurostar wrote:Salisbury Council should just buy up the shops on Old John Street, demolish them, widen the road so buses can use John Street
Try this link:
http://www.salisbury.sa.gov.au/files/assets/public/general_documents/build/developments/stc/stc_transport_assessment_report_-_july_2012.pdf
There is a public available report that cites the recommendations from consideration 6 years ago.. other documents on that page will further confirm the connection of Church Street to Gawler street. Bus routes in Salisbury might change a little into the future in the Salisbury city centre, once the new Salisbury Hub building is opened and the old council office building removed - allowing the through link - possible as early as 2020.
I can recall some suggested options in public displayed consultation reports that created a transport ring route via Gawler Street, Wiltshire Street, Ann Street and connecting back to Gawler street behind Parabanks S/C via a proposed road. Just depends on what plans DPTI and Salisbury Council can agree on into the future. Another report cites 7.5min expected frequency once electrified rail services are in operation to Salisbury.
*this post is private interpretation based on publicly available information on Salisbury Council website.*
thedom
Has thanked: 34 times
Been thanked: 25 times
Favourite Vehicle: Jumbo (on an express service)
Postby Eurostar » Tue Jan 29, 2019 3:19 pm
Try this link:
The traffic lights at Salisbury Station Interchange are kind of use less now only a handful of buses actually turn left onto Park Terrace now I.e 500 and not in service buses
Eurostar
Postby Eurostar » Fri Feb 01, 2019 9:38 pm
I remember when Commercial Road had a Go Zone. I suggest Stephen Knoll go look at Murray Road and Commercial Road in Port Noarlunga, its congested.
Eurostar
Postby jibb » Fri Feb 01, 2019 9:40 pm
Eurostar wrote:I remember when Commercial Road had a Go Zone. I suggest Stephen Knoll go look at Murray Road and Commercial Road in Port Noarlunga, its congested.
Its not him that should do it-its DPTI!.
jibb
Postby Eurostar » Sat Feb 02, 2019 9:05 am
Public transport is Stephen Knolls responsibility. DPTI is a goverment organisation. Public transport needs investment in SA not cuts.
Eurostar
Postby thedom » Sun Feb 10, 2019 8:48 pm
I suspect some of the other 'savings' suggested but not advised has included reduced carriage on late night train services - at least for the Outer Harbour line, now single carriage after 10 or 1030pm depending on direction of travel.
Have noticed since the timetable changes that at least the last 2 or 3 Outer Harbour services at night appear to be single carriage now. (With the exception of the 4 car service on Friday night for the laneway festival) over this weekend.
Wondering if Belair or Gawler lines have seen similar occurrences?
Reduced diesel costs through the year would result in savings from such changes.
thedom
Postby BroadGauge » Sun Feb 10, 2019 9:39 pm
I remember hearing a while ago that there was an operational restriction on running single carriage 3000 class units in service. Has this been lifted?
BroadGauge
Has thanked: 216 times
Been thanked: 253 times
Favourite Vehicle: Car
Postby Eagle Eye » Mon Feb 11, 2019 8:38 am
Obviously there would be a small saving in diesel, but are there any extra staff required to split consists at Adelaide in between services or can this be done using existing staff on at the time? If not that would negate some of the savings.
It would also reduce operational flexibility - i.e. a 3100/3100 consist can't be split in this manner, it has to be a 3000/3000 consist, which means earlier planning in the day to ensure the appropriate consists are rostered late at night and can be split up.
Eagle Eye
Postby Route 506 » Mon Feb 11, 2019 12:48 pm
Last Sunday I saw the Grange train was a single carriage at around 10:30am heading towards the City, so maybe this will be a regular thing on Sundays for the Grange service all day.
Now Running Express - Next Stop: City
Route 506
Has thanked: 18 times
Been thanked: 21 times
Favourite Vehicle: R.I.P. #582 (1582) 29-12-2008
Postby The Phonj » Mon Feb 11, 2019 7:15 pm
I did hear that there were reliability issues with 3000's, but since they now have new traction equipment (motors etc) these have obviously been rectified.
Get the Firefox internet browser at: http://www.firefox.com
Watch out for ghostly bus drivers!
The Phonj
Has thanked: 9 times
Been thanked: 214 times
Favourite Vehicle: MAN SL200, PMCSA body
Postby thedom » Mon Feb 11, 2019 10:40 pm
Outer Harbour services from 8:12pm onwards ex ADL tonight were all single carriage services. Grange single carriage & Belair services after 8:21pm appear to have all been single carriage services.
Gawler Central services remain at 2 carriages
thedom
Return to Discussion - Adelaide / SA
