Transport for Brisbane Observations 2019
Brisbane / QLD Transport Discussion
Moderator: PRT 065
BT Enthusiast
Favourite Vehicle: Volvo B8RLE's that run smooth
Re: Transport for Brisbane Observations 2019
Post by BT Enthusiast »
Btw 2812 is not in a wrap. I mistook it for 2848. And yes, there are only 21 L94UB's left. Check Manheim for better accuracy than BTBuses. Also, 2848 is now in service. And are all B8's up to 2854. How come BTB does not have more than 2851 when 2860 is being built at Volgren Queensland? And it still says 2847 and up are at Workshops when I went on 2852 on a 199 yesterday???
ABS
Post by ABS »
The website is maintained by a volunteer.
gen man
Favourite Vehicle: Leyland Worldmaster CRT2/1
Post by gen man »
BT Enthusiast wrote:Btw 2812 is not in a wrap. I mistook it for 2848. And yes, there are only 21 L94UB's left. Check Manheim for better accuracy than BTBuses. Also, 2848 is now in service. And are all B8's up to 2854. How come BTB does not have more than 2851 when 2860 is being built at Volgren Queensland? And it still says 2847 and up are at Workshops when I went on 2852 on a 199 yesterday???
Some people have full time jobs apart from the fleet lists!!!
need red GA:521, 831.
AAT-Kings:
2014 - Year of Privatisation!
BT Enthusiast
Have heard that W 18.310s 1459-1485 are possibly ZF Ecomat??? I did go on 1480 the other day and it did sound a bit like a ZF, although what I call 'authentic', are at Toowong. I like 1227 the most, it has a REALLY loud ZF. The Engine Startups are amazing on it. Its when the turbocharged engine actually gives out some of its power... nice. 1488 has a really loud Voith, although it's pretty annoying and disgusting.
Quite a disappointment on b8's are what bcc claims to be 'charging ports throughout the bus'. Did they give up on this?? There are ports at the front of the bus between seats but there are no ports at the back???
Would also like to see some 3-axle B8's to operate on some busier routes such as the 333,444 and 199. There were NO seats on the 199 I went on the other day and I had to stand the entire time
daveeyh
Post by daveeyh »
daveeyh wrote:
BT Enthusiast wrote:The BTBuses website is quite outdated now... don't trust it, trust your own observations.
1. It shows that 2847 to 2851 are still at Workshops, and there isn't a 2852-2856
2. 1310 up to 1325 are all at GC now, it still shows they're at T
3. I believe 2812,2817,2848 and 2849 are all in Indigenous culture AoA, with:
2812-Dreaming
2817-Distinguish
2848-Connections
2849-Dreaming
Can also add 2818 - Two Worlds.
A couple of photographs:
Two Worlds.jpeg (119.09 KiB) Viewed 6431 times
daveeyh
Post by daveeyh »
2853 (rego XQ25HL), 2854 (XQ79HK) and 2855 (XQ71HK) all parked outside the Toowong Garage today.
2856 (XQ70HK) and 2857 (XQ22HV) parked at Volgren today.
^^__^^
Favourite Vehicle: S1989 - Live well poppin' tags
Post by ^^__^^ »
BT Enthusiast wrote:Have heard that W 18.310s 1459-1485 are possibly ZF Ecomat??? I did go on 1480 the other day and it did sound a bit like a ZF, although what I call 'authentic', are at Toowong. I like 1227 the most, it has a REALLY loud ZF. The Engine Startups are amazing on it. Its when the turbocharged engine actually gives out some of its power... nice. 1488 has a really loud Voith, although it's pretty annoying and disgusting.
Reasons why the B8 artics won’t go on those routes is purely down to the design of the route itself.An Artic cannot make the left turn off Brunswick St into Ivory St Tunnel where the 199 currently goes I/B. Simple solution there would be to have all 199’s inbound follow similar alignment to the 196 again. 333, the design of Chermside interchange does not permit larger buses inside. Though, simply making the 333 service the stops outside the interchange would alleviate this issue. Artics are permitted on the 444 and were used for shuttles on NYE with some success. The main reason why you won’t see them on these routes is passenger numbers, by far and above the route with the most full standing loads is the 66, which is where those buses excel. They would be even better with all door boarding.
Favourite Vehicle: High Floor Buses
^^__^^ wrote:They would be even better with all door boarding.
Agreed, although during a visit some time ago, I noticed having two smart-card validators at every door made a world of difference (even on buses with narrow rear doors!) to the rate at which passengers can disembark.
daveeyh
Post by daveeyh »
Other than for the two CityGliders, all bus entry is through the front door. With the CityGliders, there is considerable fare evasion occurring with passengers entering through the rear door and not tagging on.
From my observations, all-door boarding on the CityGliders in the City area (and also at the Cultural Centre Busway Station) is actually less efficient than passengers boarding through the front door and the majority of passengers leaving via the rear door. There is generally a bottleneck at the rear door whilst the front door is "free".
In my opinion, the only time that all door boarding is efficient (and revenue-effective) is when there are fare gates on busway platforms as passengers don't have to deal with tagging on/off on the bus itself (but then this would require the whole route to have fare gates to enable the correct fare to be calculated).
superbossgc
Post by superbossgc »
New Timetable for western suburb + Centenary will start on 19th August, some of routes will run via legacy way tunnel instead of Milton Road and Coronation Drive, few route changing, also more early morning.
https://translink.com.au/about-translin ... /centenary
Austral Volvo B10M mk3 Artic (375-380) 1991-2012
ABS
Post by ABS »
Goodbye Centenary City Precincts. You will be missed... by not many.
The Toowong Cemetery park and ride is going to be dead.
BT Enthusiast
Anyway, what was City Precincts even for? Who wouldn't take Legacy Way over congested M5 and Coronation Drive??
What was the difference between the P457 and the P459??? Really, I think this is what should have been done years ago...
BT Enthusiast
2856 in service, rego XQ70HK on IB 444
BT Enthusiast
Went to Brisbane Airport for a flight the other day and I found they still operate a Diesel CB80 on the Airport Loop. Funny though as I thought BYD was going to take over Brisbane Airport.
Does anyone know what rego Qantas B737's with IFE have?? I went on VH-VYC with no luck...
2858 at Toowong Garage, couldn't get a rego though.
daveeyh
Post by daveeyh »
BT Enthusiast wrote:2858 at Toowong Garage, couldn't get a rego though.
XQ 37 HV
BT Enthusiast
2244 is seen mocking up a 454 on the website URL https://translink.com.au/about-translin ... /centenary. WHY would they do that?
daveeyh
Post by daveeyh »
I have noted that the new B8's are being delivered quite regularly but that the Scanias aren't being retired at the same rate.
This surprises me as I would have thought they would have wanted to re-register as few Scanias as possible in July.
I haven't been able to identify that there is a need for more buses - the changes in August to UQ and Centenary services don't look to require more buses as most new services are outside peak or replacing existing services.
daveeyh
Post by daveeyh »
T2842 is now V2842.
BT Enthusiast
WHY??? OUR B8's ARE OUR B8'S :!: :!: :!: :x :x :x
daveeyh
Post by daveeyh »
1302, 1303, 1304 and 1305 are at Garden City today.
Something I have noted is that the most recent transfers (1302 through 1308) are buses that have been at Toowong since their delivery in 2007. Pastures anew for these buses.
I also note that 1345, 1346 and 1347 are still at Toowong - is there a special reason why they haven;t gone to Garden City?
With four buses transferred to Garden City, I expect there were four Scanias retired over the weekend (which would leave 17 in service).
Cazza
Post by Cazza »
daveeyh wrote: I also note that 1345, 1346 and 1347 are still at Toowong - is there a special reason why they haven;t gone to Garden City?
Probably to try keep the kms on the bus down. They can add up fairly quickly travelling up and down the busway everyday.
New Brisbane Transport Network: https://bit.ly/35BerRD
New STA Network: https://bit.ly/2F386Ui
BT Enthusiast
Does anyone know when they're going to start retiring MAN's? Haven't seen 1200 in a few moths now...
James00
Favourite Vehicle: Bus QLD WBC88 - CB60 Evo II
Post by James00 »
BT Enthusiast wrote: Haven't seen 1200 in a few moths now...
It's currently operating a P443 this evening.
01 02 03 04 05 13 19 20 21 22 27 28 30 32 33 34 35 36 37 39 40 48 50 59 68 70 76 84 87 88 90 92 93
racingnathan
Favourite Vehicle: BT Volvo B12BLE and B7RLE
Post by racingnathan »
daveeyh wrote:1302, 1303, 1304 and 1305 are at Garden City today.
1345-1347 are currently trialing driver barriers, once complete they will make their way to GC
racingnathan
BT Enthusiast wrote:WHY??? OUR B8's ARE OUR B8'S :!: :!: :!: :x :x :x
Short term loan
Return to “Discussion - Brisbane / QLD”
