Adelaide History C McMANUS supplied Images Part 7
leyland4ever
Post by leyland4ever »
744 Morphett Bedford SB3 Perkins 8025 1-77.jpg (18.43 KiB) Viewed 3415 times
754  Leyland 270 Red Ned (original 909)  St Kilda Tram Museum 23-3-74.jpg  2.jpg
754 Leyland 270 Red Ned (original 909) St Kilda Tram Museum 23-3-74.jpg 2.jpg (11.35 KiB) Viewed 3415 times
804 Garford-Bedford 208 Nth Tce Railway Station 6-83.jpg (14.33 KiB) Viewed 3415 times
814 Prototype OBahn bus 1501.jpg (17.87 KiB) Viewed 3415 times
824 Obahn buses pass nr Park Tce 3-85.jpg (13.09 KiB) Viewed 3415 times
I've kept to more recent photos this time - I'll mix things up a bit, rather than stick to the strict chronological order the photos are in on the disc - this will minimise the number of older, poorer quality photos at any one time.
One note - I don't think the Morphett Bedford is an SB3 - unless the chassis has been radically altered - I suspect it is more likely a VAM - however the supplied caption states an SB3, so I've used that - any thoughts anyone? I suspect from the date, that the photo is taken at either Morphettville or Hackney depots - the big shift of ex-private buses to Hackney & Morphettville occurred in February 1977. It is probably Morphettville - as Morphettville did not have any petrol facilities, petrol engine buses from the southern depots (Henstridge had several), were sent to Hackney and an equivalent number of diesels came from northern depots to Morphettville. I can just recall a bus like this being used on Henstridge's South Road routes after the changeover.
Cheers
Trevor
leyland4ever
Adelaide History C McMANUS supplied Images Part 7 revised
754  Leyland 270 Red Ned (original No 909) St Kilda Tram Museum  23-3-74
804  Garford-Bedford 208  North Tce near Railway Station  6-83
814  Prototype OBahn 1501
824  OBahn buses passing  narrow section nr Park Tce  3-85
leyland4ever
Re: Adelaide History C McMANUS supplied Images Part 7 revis
I've been doing some checking about the Morphett Bedford 8025.
I found an old Morphett's fleet list from a "Bus and Coach Society of South Australia Newsletter" from the early 1970s.
Morphett's No 25 is listed as "342-732 Bedford/Perkins rebuilt Freighter C41F 1964 - Rebuilt on truck chassis."
That's a surprise!
Cheers, Trevor
Post by system improver »
leyland4ever wrote:...I don't think the Morphett Bedford is an SB3 - unless the chassis has been radically altered...
It was a converted SB3 chassis that was fitted with a Perkins 6.354 engine and was new in 1964, which was before the VAM was released in Australia. Morphett's also had 5 "normal" Freighter bodied SB3 buses when acquired by the MTT. They had a lot of Fords in the 40s and early 50s, most bodied in Melbourne by Symons & Fowler or Cheetham & Borwick. In the mid 50s they went for the UF Atkinson, bodied by either Cheetham & Borwick or Syd Wood in Sydney.
Return to “Photos - Adelaide/SA”
