NSW Railway Observations - January to June 2018
Re: NSW Railway Observations - January to June 2018
Postby Fleet Lists » Fri May 18, 2018 10:06 pm
Something I have not noticed before but for larger stations such as Campbelltown when you go to the Station information on Transport Info https://transportnsw.info/stop?q=10101296#/ there is a station map in this case https://transportnsw.info/document/1910 ... ssible.pdf
Has thanked: 1008 times
Been thanked: 1107 times
Postby J_Busworth » Fri May 18, 2018 10:35 pm
Fleet Lists wrote:Something I have not noticed before but for larger stations such as Campbelltown when you go to the Station information on Transport Info https://transportnsw.info/stop?q=10101296#/ there is a station map in this case https://transportnsw.info/document/1910 ... ssible.pdf
There are quite a few of them out there, particularly if the station has a major bus-train interchange. Some of them are out of date though, with copyrights dating back to 2016 and references to the T2 Airport line. Particularly interesting was the Mascot station map, available from the Liverpool station page, but not the Mascot station one.
https://transportnsw.wordpress.com
Eternally waiting for the Eastern Suburbs rail line to make it to Randwick
J_Busworth
Has thanked: 13 times
Been thanked: 27 times
Postby Richard290 » Sat May 19, 2018 12:13 am
The online PDF poster for Epping Station has not been updated with the removal of route 140 to Manly (26 Nov 2017), route 295 to Macquarie Centre (4 June 2017) and 630 to Macquarie Park (26 November 2017), although the current poster at Epping Station is correct.
Living at the north end of the T6 Line, 513 and the confluence of M54, 513, 546, 549, 553, 625 & 630.
Also living a mile from the Oakes Road interchange.
Richard290
Has thanked: 42 times
Been thanked: 14 times
Postby andy_centralcoast » Sat May 19, 2018 8:32 am
Trackwork on the North Shore and City Outer this weekend so everything's going via the City Inner causing some delays around Central.
andy_centralcoast
Has thanked: 48 times
Been thanked: 104 times
Postby Stonesourscotty » Sat May 19, 2018 10:47 am
M3 just went through Kingswood at speed on a Special.
Stonesourscotty
Been thanked: 13 times
Favourite Vehicle: Custom Bodied Tri Axle Volvo
Postby andy_centralcoast » Sat May 19, 2018 4:28 pm
Does anyone know what's causing the ongoing 5-10 min delays around the City Circle today for T1, T2 and T3?
Having a look at the timetable it's still less trains per hour today than a weekday peak, but some are timetabled just 2 minutes apart at Circular Quay when the minimum is usually 3.
andy_centralcoast
Postby Fleet Lists » Sat May 19, 2018 5:28 pm
You explained it two posts earlier - with trackwork like that you expect some small delays.
Postby andy_centralcoast » Sat May 19, 2018 5:41 pm
Small delays yes but there's some Penrith services running 20 minutes late "due to planned trackwork around the City Circle causing some congestions"
The Hornsby via Strathfield services recover the time at Epping where there's a 10 minute dwell stop in the timetable this weekend.
andy_centralcoast
Postby Jurassic_Joke » Sat May 19, 2018 6:32 pm
The North shore replacement bus service shutdown this weekend is a complete mess, at among the worst I’ve ever seen it.
Seems to only be one bus down the lower north shore every 10 minutes only (which sounds not too bad until you compare the capacity of an 8car double deck vs 12m standard bus) while everything else is express to City via freeway
Scania K280UB CB80 > Volvo B7RLE CB80
Millennium > Waratah
Has thanked: 49 times
Been thanked: 105 times
Favourite Vehicle: STA Scania K280UB CC CB80
Postby stupid_girl » Sat May 19, 2018 7:18 pm
Jurassic_Joke wrote:The North shore replacement bus service shutdown this weekend is a complete mess, at among the worst I’ve ever seen it.
Don't forget about the extensive bus network in lower North Shore.
stupid_girl
Been thanked: 9 times
Postby Stonesourscotty » Sat May 19, 2018 10:09 pm
Most of the S sets have had there "24 New Airconditioning trains arriving 2018" removed thought it was just S122 i was on the other night and every unit i've seen in the last 48 hours has had them removed.
Stonesourscotty
Postby andy_centralcoast » Sun May 20, 2018 9:41 am
Stonesourscotty wrote:Most of the S sets have had there "24 New Airconditioning trains arriving 2018" removed thought it was just S122 i was on the other night and every unit i've seen in the last 48 hours has had them removed.
It probably isn't a good look to advertise cool air conditioning in winter when the S set is now an ice box.
I wonder if they'll replace it with a "We know it's cold. 24 new trains with powerful heaters are coming soon to keep you warm"
andy_centralcoast
Postby Stonesourscotty » Mon May 21, 2018 5:38 am
Gaps of 50 minutes on the Western line this morning due to trains with issues at Auburn and central
Stonesourscotty
Postby sunnyyan » Mon May 21, 2018 8:47 pm
Saw today a Tangara with almost AOA. Full height advertising for CSU stretching from driver door to end of carriage, with cutouts for logo and carriage number.
sunnyyan
Has thanked: 35 times
Been thanked: 29 times
Favourite Vehicle: MB OC500LE CC CB60 Evo I CNG
Postby andy_centralcoast » Tue May 22, 2018 4:12 pm
Curious one this afternoon: T7 services are running between Strathfield and Olympic Park instead of Lidcombe and Olympic Park due to a rostering issue at Lidcombe.
andy_centralcoast
Postby boronia » Thu May 24, 2018 10:18 pm
TfNSW is advertising that the new Park and Ride with Opal at Ashfield will be active from 31 May, but I noticed when I came past today it was full of cars already.
On again June 2019
Has thanked: 262 times
Been thanked: 1649 times
Postby tonyp » Fri May 25, 2018 8:51 am
Has thanked: 873 times
Been thanked: 992 times
Postby stupid_girl » Fri May 25, 2018 3:09 pm
tonyp wrote:https://www.smh.com.au/national/nsw/passenger-crowding-on-sydney-trains-worsens-as-demand-soars-20180523-p4zh2y.html
I wonder if the situation has improved after the new train timetable.
stupid_girl
Postby swtt » Fri May 25, 2018 3:37 pm
From my limited observations, T1 Western line trains seems to have their loads much more balanced when travelling out of the city during the afternoon peak.
This is mostly due to extension of the Homebush trains to Parramatta, which then frees up the old slow Blacktown service to travel fast into Parramatta.
Sent from my Huawei Mate 9 using Tapatalk
Has thanked: 839 times
Been thanked: 366 times
Postby andy_centralcoast » Sat May 26, 2018 8:19 am
Staffing issues again these last few days causing some runs to be cancelled.
Also some interesting trackwork configs this weekend splitting lines in half.
CCN trackwork between Hornsby and Wyong. Pleasant surprise that the Hornsby to Central part still runs to the CCN timetable, which didn't happen for recent similar BMT trackwork.
T4 shut between Sydenham and Central:
- Cronulla trains terminate at Sydenham after a 10 minute dwell stop at Wolli Creek (similar to the 10 minute dwell at Epping last weekend).
- Waterfall trains terminate at Hurstville.
- SCO terminate at Waterfall.
T3 also terminating at Sydenham, but extra Kingsgrove - Ashfield runs on T2/T8 to fill the City Circle gaps for Vivid.
andy_centralcoast
Postby Fleet Lists » Sun May 27, 2018 2:46 pm
Mascot and Liverpool have been fixed after I reported the problem.
Postby boronia » Mon May 28, 2018 10:26 am
Article about Andy Byford, one time COO of CityRail/Sydney trains, and his presence in New York:
https://www.smh.com.au/national/nsw/if-you-think-sydney-s-trains-are-bad-try-new-york-s-20180523-p4zh4v.html
On again June 2019
Postby moa999 » Mon May 28, 2018 11:06 am
Please add a synopsis/title of articles, particularly when mostly OT.
This article is mostly about New York, where Andy Byford has recently been appointed.
Good old usual smh whine in the comments
Has thanked: 295 times
Been thanked: 291 times
Postby AccordV6L » Tue May 29, 2018 8:58 pm
The Endeavour in NSW Trainlink livery (N2 from memory) was having its vinyl pulled off this arvo. Saw it at Eveleigh, forgot to take photo of it
AccordV6L
Favourite Vehicle: Volvo B10BLE/APG Orana: 3860
Postby Stonesourscotty » Wed May 30, 2018 6:02 pm
Carriage 4030 (S set) has a few windows glued shut upstairs
Stonesourscotty
Users browsing this forum: Baidu [Spider], jibb, Yerolo and 11 guests
