swtt wrote:After reading the latest Rhodes East Precinct plans last night, I suspect a Rhodes Turnback might be needed to start trains fresh from there, instead of Platform 3. Trains ex Epping will be of no use by that time as Meadowbank will have been filled to the brim with new apartments, as well as Rhodes!
Apart from Epping, you can add Eastwood to that as well. It's the elephant in the room. It's a late starter, but there's already around 1,000 apartments under construction or in the planning phase and it hasn't scratched the surface yet. Further upgrading of the Town Centre planning controls will result in significantly more development. The same could be said for West Ryde.
I would expect that after the closure and conversion of the ECRL to metro, the Northern Line services via Strathfield would be 10tph at a minimum, 4tph from Hornsby, semi express from Eastwood, and 6tph all stations from Epping. Epping and Eastwood will also have CCN Intercity services. With the completion of the quad between West Ryde and Rhodes, that would allow for additional suburban services, whether semi express or all stations. In either case, Rhodes would be included, so I doubt if there would be a need for a Rhodes Turnback.
