Opal Card Fare Issues
Re: Opal Card Fare Issues
Postby matthewg » Wed Oct 30, 2019 6:30 am
boronia wrote:Both Ch 7 and Ch 9 ran news stories last night about some customers being double charged when the readers have picked up both Opal and credit cards in the same wallet. Previously. this came up as a faulty reading.
They should have been way more aggressive with their 'card clash' campaign.
I got caught out another way - I have two accounts configured in my phone. It flipped accounts with no action on my part in the middle of a trip. (I know why it did it, and I will take steps to prevent it from happening again, but traps for new players).
Opal just sent me a link to a refund form. Dunno what will happen - they now only show the last 10 transactions on the web site, so you can't even get a full weeks history anymore so I couldn't get accurate information for the form.
(They used to show ALL transactions against the card and then changed it, and no option to select how much history to display)
Has thanked: 87 times
Been thanked: 379 times
Postby boxythingy » Sat Nov 02, 2019 10:41 pm
It's ridiculous how it takes up to 20 days AND a paper based form that has to be mailed ($1) for an incorrect fare deductions review when using a contactless method! :roll:
:!: Just as Socialism with Chinese Characteristics = Joke = Rapid Transit with Sydney Characteristics
boxythingy
Has thanked: 1772 times
Been thanked: 274 times
Favourite Vehicle: Former G-Set Tangara
Postby Aurora » Sun Nov 03, 2019 9:54 am
boxythingy wrote:It's ridiculous how it takes up to 20 days AND a paper based form that has to be mailed ($1) for an incorrect fare deductions review when using a contactless method! :roll:
Think you will find that is the whole point.
Aurora
Has thanked: 155 times
Been thanked: 75 times
Favourite Vehicle: C set
Postby boxythingy » Tue Nov 05, 2019 11:08 pm
I have been racking up default fares left, right and centre when using my contactless payment method (NFC enabled phone) because the screen indicating a successful tap off has not been displaying in sync with the long vibrate, which I now suspect to mean a 'successful payment') on many of my bus journeys.
As a result, I have actually been inadvertently tapping on again (after a clearly indicated tap on, and an unclear tap off) when leaving the bus. $3 worth of postage stamps to send in 'Contactless Payments Reimbursement Forms' via snail mail and I am wondering if after 20 business days (in excess of ridiculous 1 whole month) will I get my money back.
Thank goodness the railway station readers appear to be functional, or else can you imagine:
*double default fares for both my bus and train journey transfer combination
*extra $200+potential unethical behaviour from a Government employee as a result of public shaming by a Transport Officer due to accusations that I "did not tap on"
As suspected, snail mail form as at the Sixth Day of the Eleventh Month of the Year Two Thousand and Nineteen, and barely functional contactless payment method/bus reader interfacing= hallmarks of a botched project
Use with precaution!
boxythingy
Postby moa999 » Wed Nov 06, 2019 7:47 am
Simple solution... Go back to the Opal card. Immediate fare feedback and no silly mail system.
On my test using NFC on phone it worked better on the bus than train. Part of the problem seems to be that the phone can react with a success vibration before the Opal reader does.
Has thanked: 423 times
Been thanked: 387 times
Postby matthewg » Thu Nov 07, 2019 9:44 am
moa999 wrote:Simple solution... Go back to the Opal card. Immediate fare feedback and no silly mail system.
I just spent 20 minutes on the phone being transferred between Transport and Opal because each said it was the other's problem - I can't get a history with my new credit card. The App and Web site says 'no transactions', yet there should be many. Also their billing is a week behind.
It would appear NO ONE is responsible for defects in the contactless system. I rang them as the online form is useless and no one gets back to me. Just as useless on the phone. Seems no one has the power to actually look at the system and see what's going on. The call centre doesn't appear to have any more access to the system that we do via the web site. If the web site doesn't give the answer, they can't either.
I guess I'll be going back to the Opal card at the end of this week - at least you can see if it's doing the right thing or not (and since the beginning I've only had ONE default fare, and that was probably operator error and not a defect in Opal)
Contactless has promise - and I was expecting MUCH better since it's based on London's. (Which I used 3 weeks ago - no issues at all, other than their web site is blocked for non UK internet users, had to use a VPN after returning to get the last of my transactions, but my data was all there when I finally worked out how to circumvent their block)
Postby boxythingy » Thu Nov 07, 2019 9:56 pm
I don't know when this online form was created, but I was not advised about this when I was on the phone with Opal two days ago:
https://transportnsw.info/contactless-p ... ement-form
boxythingy
Postby boxythingy » Fri Nov 08, 2019 9:01 am
There appears to be a higher undetermined minimum balance required for a successful tap off (not tap on). As it is not any of the figures under the "Minimum Balance Required to Travel tab" https://transportnsw.info/tickets-opal/opal/tapping-on-tapping-off, does anyone happen to know what it is?
boxythingy
Postby boronia » Fri Nov 08, 2019 11:30 am
Theoretically you should have sufficient balance to cover the actual fare.
But then it mentions "if your card goes into negative balance....", so they are relying on people to be honest and top up the card to cover the shortfall.
Possibly the TOs can look at your balance and at where you have boarded and determine if you have exceeded your balance distance. I wonder if they can take action if you have?
On again June 2020
Has thanked: 287 times
Been thanked: 1844 times
Postby boxythingy » Sun Nov 10, 2019 4:41 pm
Would have most definitely been charged a default fare today. For some reason a tap off using my contactless payment device at a ticket barrier did not open the gates, the second time it did not open but the yellow "concession ticket used" light lit up. It took a third go for the gate to open. Thank god for the lower $2.80 cap today.
Sent from my SM-G935F using Tapatalk
boxythingy
Postby BroadGauge » Sun Nov 10, 2019 4:50 pm
Aurora wrote:Think you will find that is the whole point.
That reminds me a little bit of how one major low cost airline in this country used to only accept requests for refunds or reimbursements by fax, despite not using fax machines for any other form of communication at all with the public.
BroadGauge
Has thanked: 216 times
Been thanked: 253 times
Favourite Vehicle: Car
Postby boronia » Mon Nov 11, 2019 11:14 am
https://transportnsw.info/contactless-payments-reimbursement-form?fbclid=IwAR2QvZSKwlKmsubzd_S8IJs-lIGGEdK45znUBD8te2PEkc3KxaxC5pE5iwA
This seems to be an online form; there is a "submit" button. Nothing here about mailing it in.
On again June 2020
Postby boxythingy » Mon Nov 11, 2019 9:42 pm
I am aware of the form, as I mentioned it earlier here:
boxythingy wrote:I don't know when this online form was created, but I was not advised about this when I was on the phone with Opal two days ago:
I also just can't believe my luck: I tapped on using my contactless method payment device when boarding the bus only for the phone to vibrate which subsequently froze the reader rendering it unusable for the next boarding passenger. I checked my device's transaction history via the Opal Card App, and nothing was in there, nor was anything recorded in the transaction history for the app I used to make the transaction/tap on with.
IF there had been a transport officer, this may have resulted in a non-compliance measure because of faulty equipment!
boxythingy
Postby Newcastle Flyer » Tue Nov 19, 2019 2:17 pm
Yet again, another Opal machine that has not been changed to AEDT. I can't tap off a train at 16:53 & then tap on a bus at 16:37 - the same day.
While it didn't affect my fare this time, the last time this happened, it was hard to get the overcharging refunded.
Newcastle Transport, please check all of your Opal Machines as some are an hour behind, even after contacting 131-500 to pass on to Newcastle Transport.
And while I'm at it, please make sure the drivers check to see if their machine shows the correct stop if a passenger says that the machine is not showing "Tap on / off.
Australia Day - the most important day in Australia
Newcastle Flyer
Has thanked: 38 times
Been thanked: 112 times
Postby Newcastle Flyer » Thu Dec 19, 2019 8:06 am
What is the name of the inward bus stop to Sydney's CBD in Randwick Shops opposite Short St?
Newcastle Flyer
Postby moa999 » Thu Dec 19, 2019 8:53 am
Just click on the stop you want in Google Maps
Postby Transport Buff » Thu Dec 19, 2019 8:55 am
Newcastle Flyer wrote:What is the name of the inward bus stop to Sydney's CBD in Randwick Shops opposite Short St?
The stop name opposite Short St in Randwick is 'Belmore Rd opp Royal Randwick Shopping Centre'. The Stop ID is 203135.
Hope this helps. :)
Love the sound of Volvo B12BLEA, Mercedes O405NH CNG, Scania K310UB
Yay - NIF!
Excited for Sydney Metro NW, C&SW
Excited for CSELR
YouTube: https://www.youtube.com/channel/UCD7ijd ... BZFksdraqg
Transport Buff
Has thanked: 19 times
Favourite Vehicle: Volvo B12BLEA Volgren CR228L
Postby Newcastle Flyer » Thu Dec 19, 2019 11:45 am
Okay thanks, the Tap on is correct, but the tap off is not, as I tapped off.
Newcastle Flyer
Postby Fleet Lists » Thu Dec 19, 2019 12:28 pm
What Tap On and Tap Off - typical lack of information from Newcastle Flyer.
Has thanked: 1119 times
Been thanked: 1227 times
Postby boxythingy » Mon Dec 23, 2019 3:08 pm
I've rediscovered a lost card (Card A) that I had transferred the money onto another new card (Card B) way back to earlier this year.
As per usual, I thought Card A was subsequently blocked.
All credit from Card B had since been exhausted (and forgotten until now), however surprisingly the value that was transferred from Card A to Card B reappeared on Card A, and it appeared to have been unblocked (or never blocked) and I was able to use this credit. Once I had exhausted all of this credit, I was informed by Opal that Card A had a "display error".
Thanks for the "partial refund" to make up for some of the inconveniences! :mrgreen:
boxythingy
Postby grimlock81 » Mon Dec 30, 2019 8:10 pm
I used to have two Opal cards for some time, but one day when I realised I couldn’t find the second one I transferred the balance to the first card and blocked the second card
It turns out I had lent the second card to my friend who lives overseas the last time she was visiting me in Sydney two years ago. She’s visiting me again this week and began using the second card with no problems and could even perform a top up on the card. However on the second day the card was marked as invalid when she tried to tapped on.
The operator on the Opal hotline explained that the taps during the first day for a blocked card was “free” and that was his explanation for the card working on the first day. I find this a strange way of blocking a card.
grimlock81
Has thanked: 3 times
Been thanked: 13 times
Postby moa999 » Mon Dec 30, 2019 9:08 pm
Interesting. Suspect the time period is the key here.
Remember that Opal operates under a 'Card is King' system - so it continues to work if machine communication is delayed. The card still thinks it has a $ value.
I'd assume the flag on invalid/tranferred cards expires after some time so readers aren't having an ever increasing list.
Seemingly some things don't work live, and so instead overnight it's been determined the card is now invalid and the flag has been sent out again after the first reusage after two years.
Postby Newcastle Flyer » Fri Jan 24, 2020 3:39 pm
Again, another fake fare (thankfully this time didn't cost anything), but it should be made known.
Tapped off at Clyde, used Red Rattler to Carlingford, and only tapped on at Carlingford to continue to several place.
My Opal activity statement said I tapped on at Clyde at 08:27. We were no where near any Opal machines at that time, we were on the platform, yet Opal cliams (again) that they are right.
Plus a few more various errors over various days.
Newcastle Flyer
Postby Fleet Lists » Fri Jan 24, 2020 3:46 pm
Before tapping off at Clyde, where did you tap on?
And when did this happen as Carlingford has now been closed for nearly three weeks?
And when you say continue to various places, you can only have tapped off at one place but you do not mention where.
As usual various much a lack of information.
Postby boronia » Fri Jan 24, 2020 5:50 pm
I'm finding it hard to understand how one person can have so many problems with a card?
On again June 2020
Users browsing this forum: Majestic-12 [Bot] and 17 guests
